Interconnect & Bi-wire
Page 1 of 1 • Share •
Hi, i m newbie here , i m looking on interconnect and bi-wire cable, any cheap and good cable to introduce , not too expensive,used also can consider , the best total up 2 item less then rm500, coz i m a poor man
heheh
heheh
khlim_77- Regular
Number of posts: 95
Registration date: 2010-03-09
Re: Interconnect & Bi-wire
hmm.. tough luck khlim. No one can really give you good answer on this. The best cable or interconnect can sound like shit on certain setups.
If you dont have a hi fi shop around that can loan you some to try out, just get the 5 star product first and try it out. Suggest u get the same brand for Interconnect & Speaker cable, so a more unified house sound for easier evaluation. There are a lot of selection in the sales section here. Do search around.
PS: Dont mind telling what setup you have? Maybe someone in this forum can help out. Thanks.
Number of posts: 425
Registration date: 2009-02-03
Hi Adrian
my current setup is
marantz CD67KI
audiolab 8000A
B&W 602 speaker
music playing is more on vocal & jazz
but some of the friend told me that i should change the power cord 1st before changing the interconnect and speaker cable
my fren say changing power cord will see the big different then changing interconnect , this that true ?
my current setup is
marantz CD67KI
audiolab 8000A
B&W 602 speaker
khlim_77- Regular
Number of posts: 95
khlim_77 wrote:Hi Adrian
Hi,
Better still is to get a good power conditioner like an isolation transformer or a good buss bar with filtration. It removes harshness and opens up the sound. Power supply is kinda like the foundation of the system.
The work your way up with speaker placements, equipment isolation methods like getting a good rack.
With the above done right I've heard systems with ordinary cables sounding good and refined.
Then comes cables and power cords to fill in the final touches.
cheers.
Wikin- Frequent Contributor
Number of posts: 276
Registration date: 2009-03-05
Source(s): PC Audio
Hi Khlim_77,
my name is Bal. When i first started this hi fi journey, my set up was a lot like yours... japanese cd player, british amp and british speakers.
I personally have not found power cords to make a big difference in sound, i can hear differences in interconnects and speaker cables much easier.
I find that QED products are very very good for the price, and it should suit your british amp and speakers. Look around, quite a few bargins here.
Stands for your speakers if they are bookshelf, and placement in the room make a bigger impact on sound compared to changes in more expensive cables. It is important, i feel, to get the basics right before going on the path of upgrading. You will find loads and loads of useful information within the threads of this wonderful website. Take some time to go thro what a lot of other members have shared in the sections on discussion of equiptment and reviews.
Take care and have a wonderful year ahead.
Bal.
Bal.
bal- Frequent Contributor
Number of posts: 283
Registration date: 2009-03-06
Source(s): Esound cdp, mac book pro with decibel thro m2 Tech and Buffalo II dac
Amplification: home made pre, vincent 330 power
Speakers: maggie MMG, Vienna acustics Haydn, Def tech BP6
Hi khlim,
If your current power cord is truly low grade(thin wiring) or havent been changing any since the original one that came along with your amp; then the difference a decent power cord will certainly be pronounced.
Certainly, power conditioning will be the best. but if you are in tight budget.. can forget about it for the moment. Sometimes, even changing the fuse of your 3 pin plug to a new one, will make a different in sound.
Try not to spend more than RM300 for a power cord.
Given your budget of RM500, it will be tough to get a brand new adn decent IC and biwire cables in one go. Unless you can get second hand.
Similar to Bal, I have used a similar set up for a good 9 years. Marantz CDP, MF amp and Epos speakers. I find that QED IC, Speaker cable and power chord does a good job in this kind of set up.
QED Qonduit is now selling at RM300 brand new. Try to find a second hand which should only fetch about RM200 and less.
elhefe- Moderator
Number of posts: 827
Registration date: 2010-02-13
Source(s): ClearAudio TT, MF M1 (CDT, DAC, CLiC, HPA, ViNL), SONY MD, ONKYO tape deck, Wadia 170i
Amplification: MF M6i Integrated Amp, M1 PWR Power Amp
Speakers: ProAc Response D18
Khlim,
My recommendations would be ;
Interconnects
Used Chord Cobra 3 - Target Rm250 +/-
Speaker cables
Used Chord Odyssey (non biwire) - RM300+/-
New Chord Rumour - RM250 +/-
Once the interconnects and Speaker cables are in place, you can always venture into playing with power cords.
Try the ones from ACE HARDWARE - Orange power cord to Diy for a start. Once you have saved enough money for a better power cord , u can transfer the power cable for your TV , etc..
I still feel that the DM602 is bass heavy, the Chords can reduce that
Interconnects
Speaker cables
- br@d -- Frequent Contributor
Number of posts: 188
Registration date: 2009-01-20
brad would know. he's been through many many types of cables/cords... and the various lengths for sonic fine tuning
Drife, - not that many le bro...
Something I have learned and tried in Singapore with a friend of mine in KEF Adelphi SG.
Try having a long power cable say 4 meter to the Source/CD player. I know its long but the sound did improved to smoother overall.
Khlim,
I believe that the orange cable was somewhere around RM8.90 per meter and you need to buy the male and female IEC from Amcorp mall or Octave Electronics Sdn Bhd. No.81 Jalan 1/12 Pj Old Town, Petaling Jaya.
Try with the 4 meter to the source. If you feel its an overkill, just split it to 2 x2 meter power cable for your source and amp. The fun bit it to play around with something that will not break the bank before venturing into more expensive power cords.
Hope this helps... Remember not to overspent
Khlim,
thank's all the Sifu, look like i hv to try out DIY myself on the power cord
Hi Brad
thank's for your help , too bad i was staying in JB, so i think i hv to find out myself on the item that u mention on,
for the B&W 602 i know it just entry level, but i can not changing thing too fast, coz not hv permission to bring back home lah ( all guy here suite know lah ) heheheh
hope that i have a chance to try on the 2 cable that u mention
tq
Hi Brad
tq
khlim_77- Regular
Number of posts: 95
Hi brad
can you please send me the ACE orange color cable picture, maybe i can find it in component shop here
thk 1st
thk 1st
khlim_77- Regular
Number of posts: 95
khlim,
You can check the link below in another topic in hifi for sale
http://www.hifi4sale.net/equipment-discussions-f6/hospital-grade-vs-normal-ac-plugs-t1490.htm
Picture is there
Alternatively you can order from uncle King from Penang. He can post for you this cheap belden cable.
http://www.mudah.my/Power+Cable-5713184.htm
Hope this helps
Picture is there
Hope this helps
Powercords does make a difference!
bal wrote:Hi Khlim_77,
Bal.
Dear Bal,
You found powercords without much effect? Have you actually connect the correct gauge size powercords? A power amp will sound its best with cords having gauge size with a minimum of 12 gauge and best performance with cord size 10 gauge. Sources need smaller gauge cords.
Go ahead try it! -Musiclink Singapore
musiclinkav- Dealer\Reseller\Trader\Service Provider
Number of posts: 157
Registration date: 2009-11-29
Hi khlim,
I've got signal cable (http://www.signalcable.com/) 1m interconnect silver resolution with eichman silver bullet RCA or xlr (USD170.00) & 8ft bi-wire ultra (USD156.00) cable together with QED power cord (white spiral thingy in clear plastic jacket) if you are interested. All of these for your budgeted price. Got too many cables.... They are quite good & value for money. You can read the customers feedback on their website. I work in KL (Dayabumi). Call me on 012 3720618 if u are interested or anybody else. Not really into selling things but just wanted to help out
Best
Best
mohfudz- New Member
Number of posts: 17
Registration date: 2009-05-13
Similar topics» Straight Wire Sonata interconnects (New)
» Straight Wire Chorus interconnects (New & Demo) SOLD
» Organizer/reel for bonsai wire
» clip and wire raft
» Heavy Duty Wire holder HD Movie
» HI5LOFT brings back Xindak!
» NAD C326BEE Amp (Used)
» Copper color PENNY V power cord
» SQUARECIRCLES - Immediately Seek Attention
» SEAS Excel woofer
» Musical Fidelity F22 (used)
» Philips CD104 (used)
» Amperex 6dj8/ECC88
