Pioneer A-400X Integrated Amplifier(sold)
The Pioneer A-400X Integrated Stereo Amplifier featuring its wide range
linear circuit. With a power output of 50 Watts per channel, it has no
problem driving a 5 foot floor standing loudspeakers with ease. With it
performance, It is able to produce punchy, dynamic and detailed sound.
Specifications:
Continuous power output (both channels driven at 20 Hz to 20kHz)
70W + 70W 4 Ohms, 0.03% THD
50W + 50W 8 Ohms, 0.02% THD
DIN Continuous power output (both channels driven at 1 kHz)
85W + 85W
into 4 Ohms. 1% THD
60W + 60W into 8 Ohms. 1% THD
Dynamic power output (on EIA dynamic test signal)
150W/100W/70W into 2 Ohms /4 Ohms /8 Ohms
Total Harmonic Distortion
0.02% at 20Hz-20kHz , 50 W, 8 Ohms
0.03% at 20Hz-20kHz , 70 W, 4 Ohms
Frequency Response
1Hz-300 kHz + 0/- 3 dB (CD, Tuner, Aux, Tape)
20Hz-20 kHz +/- 0.3 dB (Phono MM)
20Hz-20 kHz +/- 0.5 dB (Phono MC)
Signal-to-Noise ratio (IHF short circuit, A network)
110 dB (CD, Tuner, Aux, Tape)
86 dB / 67 dB (Phono MM, 2.8 mV input, Phono MC, 0.24 mV input)
Signal-to-Noise ratio (DIN, continuous power/50 mW)
93 dB / 71 dB (CD, Tuner, Aux, Tape)
74 dB / 68 dB (Phono MM)
Input sensitivity/impedance
CD, Tuner, Aux, Tape 200mV/ 40 kOhms
Phono (MM) 2.8mV/ 50 kOhms
Phono (MC) 0.24mV/ 100 Ohms
Power supply...................................240V AC, 50/60 Hz
Power Consumption.........................520 watts
Dimensions(w x d x h)......................42 x 35.2 x 12.6 cm
Weight............................................8kg
Miscellaneous:
Made in...........................................Japan
Condition.........................................8/ 10
Price: soldso
If interest pls sms me chung 012-8877916
Last edited by chung on Fri Mar 02, 2012 12:26 pm; edited 1 time in total (Reason for editing : sold)
chung- Frequent Contributor
- Number of posts : 156
Registration date : 2010-02-10
» Pioneer A-400X integrated amplifier (sold)
» Pioneer A-400X Integrated Stereo Amplifier (Used) SOLD
» Pioneer A-400x Integrated Amp (used)sold
» Pioneer A-400X integrated amp (sold)
» Pioneer A-400X integrated amp (used) SOLD
