Klipsch RS-42 Surround Speaker (Sold)
FREQUENCY RESPONSE 52Hz-23kHz +/-3dB
POWER HANDLING 75W RMS / 300W Peak
SENSITIVITY 93dB @ 2.83V / 1m (equivalent sound energy)
NOMINAL IMPEDANCE 8 ohms compatible
HIGH FREQ CROSSOVER 1700Hz
HIGH FREQUENCY DRIVERS Dual 1" (2.54cm) Titanium diaphragm compression drivers mated to 90x60 square Tractrix® Horns
LOW FREQUENCY DRIVERS Dual 4" (10.2cm) Cerametallic™ cone woofers
ENCLOSURE TYPE Bass-reflex via dual side-firing ports
HEIGHT 10" (25.4cm)
WIDTH 10.75" (27.3cm)
DEPTH 7.75" (19.7cm)
MOUNTING Keyhole bracket and Dual 1/4"-20 threaded inserts
WEIGHT 10lbs (4.5kg)
FINISHES Matte Black vinyl
BUILT FROM 2006
BUILT UNTIL 2010
Condition: 9/10
High-performance surround speaker
WDST™ design for maximum coverage and ease of placement
Clean, compact shape for minimal room intrusion
Delivering detailed and lifelike performances, the Reference Series RS-42 brings a new dimension of reality and convenience to the world of surround sound. Offering superior technology and elegant design at an enticing price, this surround speaker let's you experience the full impact of high-performance special effects.
Adopting a completely new cabinet and driver layout that is similar to the Klipsch THX® Ultra2 KS-525-THX surround speaker, the RS-42 establishes greater output, improved coverage and increased power handling to further extend Klipsch's best-in-class surround sound performance.
Exclusive Tractrix® Horns have always been the key component of the Reference Series. In the RS-42, this technology has been refined to include improved throat geometry for a more genuine, lifelike sound. Behind the speaker's dual horns lie 1-inch titanium tweeters with powerful neodymium magnet motor structures to provide a unique combination of precision, clarity and effortless dynamics.
The RS-42 employs dual 4-inch woofers for a solid bass foundation. These Cerametallic™ woofers with inverted copper dust caps exhibit a very high stiffness-to-mass ratio and superb damping characteristics.
Klipsch Wide Dispersion Surround Technology™ (WDST) provides crystal-clear sonic detail even in listening areas with less than ideal configurations. The Tractrix Horns deliver a 90-degree wide by 60-degree high dispersion pattern. By aligning two horns at 90-degrees with respect to each other, WDST smoothly covers a 180-degree horizontal arc. In other words, the surround sound is pointed at you no matter where you are seated.
While increased baffle ribbing around the horn mouth dramatically improves acoustics across the sonic range, the crossover utilizes Klipsch custom internal wiring and the finest components to provide signal purity and perfect driver integration.
Available in a matte black vinyl finish, the RS-42 also features side-firing ports to eliminate turbulence noise and back-panel keyholes and ¼" threaded inserts to simplify installation. A low-diffraction, magnetically attached grille further accentuates the elegance of this speaker.
Asking for: Sold
Interested pls call/sms Ronald 012-4476622.
ronaldjoe- Regular
- Number of posts : 79
Registration date : 2009-07-31
» Klipsch R-14S Surround Speaker (Used) SOLD
» Klipsch CA-5T Surround Speaker (sold)
» Klipsch Reference IV Surround Speaker RS-42 (Used) - SOLD
» Klipsch SS-1 Dipole Surround Speaker SOLD
» Klipsch synergy s2 surround speaker (sold)
