The Oyaide Tunami Power Cable Unterminated (Used)SOLD
The Oyaide Tunami Power Cable Unterminated (Used)SOLD Empty The Oyaide Tunami Power Cable Unterminated (Used)SOLD
Post by raymond88 Wed Jan 26, 2011 10:58 am
The Oyaide Tunami Power Cable Unterminated (Used)SOLD Oyaide18
Item:
The Oyaide Tunami Power Cable Unterminated - 1m
The Oyaide Tunami Power Cable Unterminated - 2m SOLD
Condition: 8.5/10. Very good condition
Contact: Raymond 012-3816611
The Oyaide Tunami Power Cable Unterminated (Used)SOLD Oyaide19
The Oyaide Tunami Power Cable Unterminated (Used)SOLD Oyaide20
Some info:
Overview
A New Standard, The "TUNAMI"
Oyaide Electric with the experience gained from a long history of cable design, has developed a reference standard power cable called the "Tunami". The cable is constructed using PCOCC-A wire developed by Furukawa Electric using advanced heat control and extrusion technology.
The cable utilizes a 5.5 sq. mm conductor core that is rated up to 30 amps and can take up to 600 volts A/C. This makes it a leaderin its class deliveringa powerful sound. In addition it has a unique 3 layer shielding system not only to shut out external noise but also to suppress internal noise resulting in a very low noise floor.
The combination of advanced and creative technologies delivers every intention of musicians with the delicateatmosphere around them.
PCOCC-A
This is an ultra pure single crystal copper originally developed by Professor Ohno. It was then further evolved into PCOCC utilizing a single copper grain wire. This design results in an extremely low level of signal disturbance and loss factor due to the lack of crystallinebordersin the signal path.
We have further evolved this technology with a highly controlled heating and cooling process and improved surface management to realize mirror finish. It is now called PCOCC-A and it is the eepitome of Japanese craftsmanship.
3-Layer Shielding
It is a fundamental requirement for cables to be protected from external noise. Oyaide has been a leading force with our traditional star-quad structure.
We have gone a step further with the "TUNAMI", employing a unique 3 layer shielding system.
The first layer absorbs the disorders of electro magnetic field formation; a second carbon layer is used to absorb therandom movement of electrons from current fluctuation stored in insulating materials and a final third copper foil layer with a drain wire to protect from external noise sources. The Drain wire is then connected to the "ground" for perfect shielding
Insulator
It is our philosophy at Oyaide to try every possibility until we achieve the best harmony of materials to use. We researched various hardness / density of insulation materials to determine the most ideal resonance control ability. The result was to use varying grades of high polymer polyolefin in the internal structure for the maximum effect.
We then developed a method to apply the insulation covering onto conductors with higher tension for a more constant and secure fitting.
http://www.oyaide.com/e_audio/audio_products_files/tunami.htm
http://www.stereotimes.com/comRN040109.shtml
http://www.takefiveaudio.com/mall/shopcontent.asp?type=Tunami_PC
Last edited by raymond88 on Thu Jan 27, 2011 8:44 pm; edited 1 time in total (Reason for editing : SOLD)
Number of posts : 10058
