The Chord Company Anthem RCA interconnects 0.5m
The Chord Company Anthem RCA interconnects 0.5m Empty The Chord Company Anthem RCA interconnects 0.5m
Post by raymond88 Mon Jan 31, 2011 9:22 am
The Chord Company Anthem RCA interconnects 0.5m Chorda10
Item: The Chord Company ANTHEM RCA interconnects 0.5m
Condition: Used 8.5/10. It is in excellent condition.
Price: RM850 neg
Contact: Raymond 012-3816611
The Chord Company Anthem RCA interconnects 0.5m Chorda11
The Chord Company Anthem RCA interconnects 0.5m Chorda12
Some info:
The Anthem is the state of the art interconnect which will bring unprecedented levels of detail, timbre and coherency.
This cable is a natural evolution of three years research into cable geometry, shielding and the critical relationship between conductor and insulation materials. The conductors and shield are silver plated and the insulation is Teflon. Screening is a unique wire foil structure that provides truly effective high frequency noise rejection. The RCA plugs fitted to the Anthem carry Chord Co's thoughts on conductors to a logical conclusion. They keep surplus metal to a bare minimum and all parts of the plug are silver plated.
The Anthem is revealing and dynamic, but above all enticingly musical.
Noise and interference are the great enemies of
reproduced music.The shield system of the Anthem
dramatically reduces these and the music sounds more coherent as a result. Subtle tonal differences are easy to hear, as are the tiny dynamic changes that are so critical to the realism of a piece of music. The Anthem will work beautifully with CD players and is outstanding when used with turnables and phono stages.
What is it?
The Anthem departs from the twisted pair design found in most of our other cables and on top of that, departs from the balanced geometry that we use so much. Three runs of high performance 50-Ohm coaxial cable are sheathed with black tubing and woven together. The central conductor of one of the coaxial cables carries the signal and the remaining two central conductors carry the return. The design was arrived at after lengthy experimentation.
The shielding system is a complex combination of foil and silver plated round wound wire and is extremely effective at very high frequencies. Plugs are of course silver plated but in this case we use a very stripped down design, the shield is modified and the entire surrounding metal casing is removed. Listening tests have shown that the less metal around a plug, the better the sound. Once the cable has been soldered the joints are reinforced with a heavy-duty adhesive heat shrink.
The Anthem allows you to hear more detail than any of the preceding cables in our range and this is partly due to the configuration, but more importantly the efficiency of the shielding. The shield uses a foil wrap around the conductor, which in turn is over wrapped with silver plated wire (imagine a very tight spiral). This is then dipped in a solder bath to produce a really effective shield system that is still flexible. The effectiveness of the shield means that the noise floor of the cable is lowered. This simply means that it is possible to hear more low-level information because it is not being masked by noise. Noise in this case is picked up along the length of the cable; the less noise that is picked up, the lower the noise floor. The leading and trailing edges of notes become simpler to hear, this is vital to the timing of a piece of music and music sounds far more coherent as a result.
Tonal subtleties are also much easier to hear. A good example of this is the difference between various types of piano and another fine example would be the differences in tone between a Fender Precision bass and a Fender Jazz bass. These are two of the most popular basses in the world and whilst they are both basses, the Precision has a slightly percussive, wooden tone whilst the Jazz has a deep, growling tone. There have been good reviews of the Anthem in Hi-Fi World.
Item: The Chord Co, Chord Chorus 2 Interconnect 0.5m pair
Condition: Used 8.5/10. Demo unit. It is in MINT condition and comes complete
with original box and packaging materials.
Price: RM780 neg
The Chord Company Anthem RCA interconnects 0.5m Chorus10
The Chord Company Anthem RCA interconnects 0.5m Chorus11
Some info:
  • Chord Chorus 2
  • 2 RCA to 2 RCA Audio Interconnect
  • The Chorus 2 benefits from the combined shielding system first developed for the Chord Signature and the Chord Indigo interconnect cables.
  • The shielding system on the Chorus 2 is used to protect the Teflon insulated, solid core silver-plated signal conductor.
  • The signal return path is carried externally ensuring that the central signal conductor is completely isolated.
  • The combination of the silver-plated conductor and Teflon insulation enables the Chorus 2 to accurately carry a wide bandwidth signal.
  • The very low noise floor produced by the tri-layer combined shielding system, ensures that the micro dynamic and the complex harmonic and tonal information that make up the timbre of instruments is neither lost nor masked by noise or interference.
  • The outstanding shielding capabilities of the tri-layer shield will be obvious regardless of the system the Chorus 2 is connected to. Individual notes snap into focus, snare drum beats are properly dynamic and resonant, and stringed instruments gain real tone and timbre.
  • The Chorus 2's ability to carry dynamic information means that music is presented extremely coherently and even complex rhythms are simple to follow. stereo image will be both wide and extremely stable.
  • Multi-strand oxygen free copper conductors
  • Low density polyethylene dielectric
  • Matched signal and return paths
  • Floating lapped shielding
  • High quality gold-plated RCA (phono) plugs
  • Vibration damping PVC outer jacket
    http://www.futureshop.co.uk/chord-new-chorus-2-2-rca-to-2-rca-audio-cable-1m-p-1139.html
    http://petertyson.co.uk/ebuttonz/ebz_product_pages/chord_chorus_2.shtml
    See my other items at www.mudah.my/hifi-junction
    Thank you.
    Thank you.
  • raymond88
    Number of posts : 10058
