Audiophile USB cable anyone ?
Page 3 of 3 Previous  1, 2, 3
Re: Audiophile USB cable anyone ?
Post by adrian4454 on Tue Mar 22, 2011 5:00 pm
Thanks Mugen for pointing this. Recall some of the syllabus surrender back to lecturer last time.
Anyway, the data is transmitted using frequency, using frequency-shift keying... never in the discrete block we see, which is basically the encoding only..
adrian4454
Male Number of posts: 425
Registration date: 2009-02-03
Post by mugenfoo on Tue Mar 22, 2011 5:18 pm
actually its in discrete blocks, if u go and Google up a typical pattern for Bi-phase mark code. Basically you will need double the bandwidth to carry a given payload.
Now, back to the matter at hand is how "clean" and how timely can the discrete square waves be transmitted. Hence jitter and noise degradation comes into play here.
mugenfoo
Male Number of posts: 2665
Registration date: 2009-04-04
Source(s): Marantz
Amplification: Exposure
Speakers: Harbeth P3ESR
Post by adrian4454 on Tue Mar 22, 2011 5:35 pm
Hi Mugen,
Yes, the encoding is illustrated in discrete block. but when transmitting it, it is done through frequency just like analogue... As explained in frequency-shift keying...
Anyway, if it isnt... do correct me. Thanks.
adrian4454
Post by sflam on Tue Mar 22, 2011 6:10 pm
i'm a bit puzzled. jitter and noise degradation come into play in the connection (usb or others) between digital player and dac.
but between external hard disk and digital player?
sflam
Male Number of posts: 539
Registration date: 2009-03-09
Post by mugenfoo on Tue Mar 22, 2011 7:05 pm
adrian4454 wrote:Hi Mugen,
you are correct . a cable or optical link will never truly carry a perfect square wave signal. Hence the "analog" portion of any signal carrying medium.
So even if the modulation is by frequency shifting, there is always an "innacurate" element to the freq shifting. hence this gives rise to jitter and noise problems.
mugenfoo
Source(s): Marantz
Post by hasnul on Sat Apr 16, 2011 1:20 pm
Anybody using USB cables from Locus Design ?
hasnul
Male Number of posts: 256
Registration date: 2009-01-22
Source(s): Hiface EVO + AudioGD DAC19, Thorens TD125 MKII + SME 3009 S2 Imp. tonearm
Amplification: Sansui AU-7500/ Primaluna Prologue 2 + Pipit 22L
Speakers: B&W DM4
Post by dynon on Sun Apr 17, 2011 11:52 pm
I am using WireWorld Starlight USB. I am satisfied with the sound quality. Other famous USB cables are Furutech, Audioquest Carbon,Coffee and Diamond, Zonotone and Transparent.
dynon
Male Number of posts: 23
Registration date: 2010-10-08
