WTS: Waterfall audio Victoria EVO 3 Way Glass Speakers
Selling the following speakers @4000 Nego 92737611
Mint Condition
Review : http://www.hemagazine.com/Waterfall_Audio_Victoria_Evo_Review
Features:
6mm High Density Krysta-Line Glass, not only a stately and beautiful material, because of its high density, also helps eliminate unwanted vibrations from the structure of the loudspeaker, therefore providing perfect sound reproduction
The use of excellent quality drivers together with our patented system "ADT" (Acoustic Dampening Tube) allows proper functioning of a loudspeaker in a non-dampened structure, guarantees a quick, sharp bass and a mid-range reproduction
The Treble Frequency is reproduced by a new generation of Neodynium Magnet Tweeters, delivering a very smooth and delicate sound. The Crossovers, enhanced by the new "Acculiner" technology, control the tuning of these exceptional driver units
3 way-4 speaker design. Recommended Amplifier for best results, between 40 and up to 250 Watts: Peak power performance 500 Watts: Impedance (over/min) 8/4 Ohms, Efficiency (283V/1m) 89dB
Frequency response (+/- 3dB) 40Hz - 28Khz, Tweeter (neodynium) 8" silk dome, Driver unit bass/midrange 2 x 6" Tunable passive radiator compression for room variances. Victoria's Dimensions 40" tall, 10" wide by 10" deep and 38 lb's each
Specifications:
Type: 3 Ways, 4 Drivers
Recommended Amplifier: 40-250 Watts
Peak Power: 500 Watts
Impedance (Average/Min): 8 / 4 Ohms
Efficiency: 89dB
Frequency Response: 40Hz - 28kHz
Tweeter (Neodymium): 0.8" Silk Dome (20mm)
Driver Unit Bass/Midrange: 2 x 6" (150mm)
Ultra Low Frequency Driver : 8" (210mm)
Dimensions L x D x H: 10" x 10" x 40"
Mint Condition
Features:
Specifications:
Efficiency: 89dB
lonesax- Dealer\Reseller\Trader\Service Provider
- Number of posts : 66
Registration date : 2010-10-02
» WTS: Waterfall audio Victoria EVO 3 Way Glass Speakers
» WTS: Waterfall audio Victoria EVO 3 Way Glass Speakers (USED)
» WTS: Waterfall audio Victoria EVO 3 Way Glass Speakers (Used)
