IsoTek 'Optimum' High Current Mains Cable 1.5m (Used) & Russ Andrews
Item: IsoTek Optimum High Current Mains Cable 1.5m long. Terminated using high quality MK Duraplug & IsoTeks unique 24ct gold deep cryogenically treated IEC connector.
Condition: 8.5/10. Item is in mint condition.
Price: RM890
Contact: Raymond 012-3816611
Some Info:
Retail Price: £275.00
Our Price: £275.00
You Save: £-0.00 (-0%)
IsoTek Optimum High Current Mains Cable features large oxygen free conductors rated at 20A, a high quality MK Duraplug as well as IsoTeks unique 24ct gold deep cryogenically treated IEC connector.
Radio frequency interference is universally regarded to be a major problem in high quality audio and video replay. As all cables act as antenna and attract RFI, it was vital to provide an affordable solution to this problem whilst maintaining neutrality within the cable design.
The Optimum uses the same high grade Oxygen Free Copper as the Elite, but with larger conductors rated at 20A. This makes it ideal for use with amplifiers and active speakers and anything else which may draw a large amount of current. The Optimum features a high quality copper plug and an IsoTek high quality IEC connector
All IsoTek cables are built by hand to extremely high standards. Optimum Mains Cables provide a solution without sacrifice to the audio signal. Three high-grade cores of annealed Oxygen Free Copper conductors are encased in a highly flexible PVC inner sheath surrounded by a braided screen. This earthed screen forms an active RF shield around the inner cores. The effect is a reduction in the background mush within the system, producing a more open airy sound with a greater sense of high frequency detail. Rated at 20A, makes this cable ideal for all components especially power amplifiers, power supplies and of course mains conditioning devices. The Optimum Mains Cable also features IsoTeks unique 24ct gold deep cryogenically treated IEC connector as well as high quality MK Electric copper plug. This allows for maximum power transfer, long-term reliability and performance.
SPECIFICATION
- IsoTek Optimum High Current Mains Cable
- Length 1.5 metres.
- 24ct gold deep cryogenically treated IEC connector. This allows for maximum power transfer and performance. All conducting surfaces deep cryogenically treated and demagnetised.
- IEC Connector features a large diameter, durable Polycarbonate body for easy handling and mechanical stability. High precision nylon front body for accurate mating with main outlets
- MK Duraplug - High Quality MK Copper Plug
- Triple Shielded
- OFC Conductors
- Conductor: 3 x 2.5 sq mm
- Insulation: High Quality PVC
- Power Rating: 20A
- Shielding: Aluminium/Polyester
- Resistance: < 8 Ohm / KM
- Suitable for use in any application requiring an IEC(C13) connector
- 25 Year Guarantee on Completion of IsoTeks Registration Card
Some links:
http://www.thesoundsmiths.com/files/downloads/other_files/Sound%20Advice%20-%20IsoTek%20Premium,%20Elite,%20and%20Optimum%20mains%20cables.pdf
http://www.futureshop.co.uk/isotek-optimum-high-current-mains-cable-15m-p-1240.html
https://www.youtube.com/watch?v=OLyMG1hv-n8
My other power cords:
Item: Russ Andrews Kimber Kable High Current PowerKord - 1m & 1.2m long. Terminated using MK plug & Wattgate 320i IEC.
Condition: 8.5/10. Items are in excellent condition.
Price: RM380 for 1m lenght & RM420 for 1.2m lenght
Item: Russ Andrews PowerKord with Super Clamp - 3m
Condition: 8/10. In very good condition
Price: RM460
» Russ Andrews Kimber Kable High Current PowerKord - 1m & 1.2m (Used)
» Power Cords: PS Audio/Russ Andrews/Isotek/Furutech
» Russ Andrews QRT Quantum Symphony with Russ Andrews power pack(SOLD)
» Russ Andrews PowerLink UK 4 way Audiophile Mains Lead using Kimber Kable PK14 Leads - 2m (Used)SOLD
