WTS: Modwright 36.5 two-box dual mono tube preamp
Selling a perfect working and cosmetic condition
Modwright 36.5 two-box dual mono tube preamp. This is the one with the
external power supply, PS 36.5.
Asking SGD$9000, comes with upgraded tubes.
Can ship to Malaysia if needed.
Email black.blanc@gmail.com
Read the reviews!
http://www.positive-feedback.com/Issue38/modwright_36.htm
http://www.6moons.com/audioreviews/modwright4/365+_3.html
* Tube compliment: (2) 6H30 signal tubes (Upgraded 6H30 Reflektor Super tubes; best 6H30 tubes available.)
* Tube rectified power supply (Upgraded Tungsol 5U4GB tubes pair)
* Gain: ~12db
* Input impedance: 50 Kohm
* Output Impedance: 110 ohm
* Frequency Response 20Hz - 100Khz +/-1dB
* Noise Level: -125dB
* Choke loaded power supply
Full complement of MWI Custom capacitors - designed by ModWright to
provide no sonic compromises. Pure Teflon film/foil and oil-impregnated
poly caps in power supply and signal path* External tube rectified power
supply
* Discrete Constant Current Sourced B+ regulators
* DC heaters
* Gain Stage: Pure Class A, cathode bias "Mu" gain/buffer stage w/ zero feedback
* Power Sequence: Mute delay turn on with soft start for improved tube life
* Volume Control: Remote control Alps motorized volume control
* Dimensions: 17.5"W x 12.5"D x 4.75"H
* Weight: 34 lbs pre & approximately 35 pounds for the power supply.
Testimonials:
"The
SWL 9.0 modeled itself closely on high-resolution transistor sound,
i.e. neutral down the middle. The LS-36.5 stays the course but digs deep
into the space drawer of dimensionality and layering where tubes hold
the aces. It's really amazing how far Dan Wright has come in a short
time as a manufacturer. At its price, the LS-36.5 is a very strong
statement to make both its designer and future owners proud….the LS/PS
36.5's low gain and very gradual volume taper coupled to its exceptional
noise behavior is simply perfect…….If you view audio important enough
to warrant long-term investments into personal gratification and
listening indulgence, the LS/PS 36.5 combo is a guaranteed high-yield
stock. Dan Wright's math continues working because the sonic performance
advance of going offboard with the power supply and more than doubling
it to provide each channel with what both had together before; plus
more... there's a still solid return on investment you won't strain to
hear and appreciate. ModWright now means more than high value. With this
duo, it means statement effort for all but the financially completely
liberated."
- Srajan Ebaen, sixmoons review site (this preamp is Srajan’s reference tubed preamp currently)
"Insofar
as system matching goes, the ModWright 36.5bwould be a terrific choice
for 99% of digital & solid-state systems that are in need of
musicality to facilitate long term listening satisfaction. And
surprisingly, the Modwright 36.5 also told me about faults that I never
knew existed in gear that is much more expensive than it is; that, my
dear reader, is what this reviewer calls "wildly exceeding
expectations". Musically satisfying in all the ways that serve the
music, the ModWright 36.5 is a dandy of a preamp."
- Ryan Coleman, Dagogo(dot)com
Read the reviews!
* Gain: ~12db
supply
* DC heaters
Testimonials:
"The
liberated."
"Insofar
paperlogos- New Member
- Number of posts : 8
Registration date : 2011-04-22
» Gryphon Bel Canto Dual Mono Preamp & Gryphon DM100 Dual Mono Class A Power Amp (Used) SOLD
» Musical Fidelity A3CR Dual Mono Preamp and A3CR Dual Mono Power Amplifier
» WTS: Modwright LS36.5 Tube Preamp with PS36.5(Used)
» Modwright SWL 9.0 SE (Signature Edition) tube preamp MINT with box
» SOLD HIFI preamp dual mono design
