Monitor Audio HD90 Mini Bookshelf Speakers (Used)
Monitor Audio HD90 Mini Bookshelf Speakers (Used) Empty Monitor Audio HD90 Mini Bookshelf Speakers (Used)
Post by D_Y2k.9^ Thu Jun 02, 2011 11:08 pm
Monitor Audio HD90 Mini Bookshelf Speakers - Black Glossy RM690
Interested party may contact me at 0172503131
COD in KL/PJ
Condition: 9/10
Monitor Audio HD90 Mini Bookshelf Speakers (Used) IMG_0007
http://www.monitoraudio.co.uk/products/radius-hd/r90hd/
Review: http://www.whathifi.com/review/monitor-audio-r90-hd10/
Features
-4" MMP®II. The Metal Matrix Polymer drivers have been completely re-worked and re-modelled with the aid of new design and simulation tools to achieve higher sensitivity and increased magnetic linearity. The new shaped T-section pole and focussed magnetic gap produces better linearity and lower distortion, resulting in fast punchy bass. All drivers are dedicated and model specific, with each model in the Radius HD series being designed and voiced individually.
-1" Gold C-CAM® tweeter providing extension to in excess of 35 KHz ensuring the wide frequency bandwidth of HD music and cinema formats can be replayed faithfully.
-Magnetically shielded drivers allow Radius HD to be safely used near sensitive microprocessor equipment or plasma/LCD displays.
-High quality crossover uses high-grade metalised Polypropylene capacitors for increased clarity. High-grade air core and laminated iron core inductors give lowest possible distortion and low insertion losses.
-Single through-bolt driver fixing provides mechanical de-coupling and enhanced mid-band clarity and resolution. The through-bolts also act as rigid cross bracing to give a very solid non-resonant cabinet.
-Internal PTC auto-reset protection circuit to prevent over-driving.
-Specially developed high grade PCOFC internal cable is used throughout to ensure maximum signal transfer at all frequencies and low signal resistance.
-Flush fitting grille with rotate-able ‘m’ logo for positioning in Landscape or portrait orientation.
-A specially designed die-cast metal wall bracket is supplied, providing easy install and adjustment for wall positioning.
D_Y2k.9^
Number of posts : 449
