Cyrus Audio 8xpd Integrated Amp (Used)
Cyrus Audio 8xpd Integrated Amp (Used) Empty Cyrus Audio 8xpd Integrated Amp (Used)
Post by D_Y2k.9^ Thu Jun 02, 2011 11:10 pm
Cyrus Audio 8xpd Integrated Amp with built in DAC
RM7,900
Condition 9/10 - Like Brand New
Reason for sale: Hardly use
Interested party may pm or contact me at 0172503131
Cyrus Audio 8xpd Integrated Amp (Used) IMG_0017-1
Specifications:
Continuous Power - 115 W/CH (into 4 Ohms) 70 W/CH (into 8 Ohms)
Burst Power - 320 W (IHF, one channel driven into 1 Ohm)
Distortion - 0.002%, 1kHz (into 8 Ohms) 0.005%, 1kHz (into 4 Ohms)
Frequency Response - -3 dB, 0.1Hz and 100kHz
Damping Factor (1kHz) - 150
Input sensitivity (70W) - Line: 237mV
Input impedance - 40kOhm (RCA).
Output voltage - 237mV (Tape out), 480mV (Pre out)
S/N Ratio - 105dBA (ref. 40W)
Channel Balance - ±0.2dB (0dB to -63dB)
Volume control accuracy - ±0.1dB (0dB to -63dB)
Dimensions (H x W x D) -73 x 215 x 360 (mm)
Weight - 5.9 kg
Finish - Quartz silver or Brushed Black
Digital audio performance, 8 XPd model Pre-out
Input voltage - 500mV pk-pk
Input Impedance - 75 Ohms
Sample rate range - 32k – 96k
Audio formats - PCM stereo only
S/N ratio (Pre out, 0db FS) - Better than 100dba
THD+N (pre-out, 0db FS) - Less than 0.004%
D_Y2k.9^
Number of posts : 449
