Enacom Speaker audio noise suppressor (Used) SOLD
Guys,
time to say good bye to one of my favorite tweaks the Enacom Speaker Audio Noise Eliminator. Really works to have a darker background sound and reduce that humming sound. Reviews are below.
Selling at : RMSOLD with spade connectors
Condition: 9/10 (had it for close to a year)
Feel free to contact me at :
016 7777 880 - Brad
COD PJ or SUBANG
Free delivery anywhere in Malaysia via Post Laju. Sabah & Sarawak Included
Review:http://www.positive-feedback.com/ambackissues/enacom.htm
"The Enacom "filters" are interesting products. The AC Enacom is claimed to reduce EMI and RFI in your household power lines by means of parallel filtering. Parallel filtering or conditioning refers to units that are plugged into an AC receptacle, but do not feed power to another component. That is, none of your audio gear is plugged into these devices. They do their magic by being plugged into the wall. These products range from the simple Quietlines by AudioPrism to the recondite ElectraClear EAU-1. An in-line device, or power line conditioner, allows your components to be plugged into its AC receptacles, feeding your gear with "cleaner" power. There are numerous approaches to the design of in-line conditioners. All will produce a change in your systems sonics; whether this change is good, bad, or even evident is up to you. They will all do something, but only you can decide whether it is worth the fee. The speaker Enacoms, it is claimed, reduce speaker/amp load resistance distortions as well as RFI that may be evident in your listening environment. These attach, via black and white pigtails, between the positive and negative binding posts on your speakers. If you bi-wire, two per speaker (four total) are suggested."
- br@d -- Frequent Contributor
- Number of posts : 336
» Enacom Speaker Audio Noise Eliminator
» Enacom Speaker noise supressor (Used) SOLD
» Harmonix ENACOM Speaker Noise Filter (Used) SOLD
» Hewlett Packard 5 KVA Balance Isolation Transformer Noise Suppressor (SOLD)TQ
» Enacom S.P Cord - Audio Noise Eliminator
