NHT A-1 monoblock power amps (Display)
NHT A-1 monoblock power amps (Display) Empty NHT A-1 monoblock power amps (Display)
Post by sollehah Mon Jun 15, 2009 4:24 am
NHT A-1 monoblock power amps (Display) Nowhea10
NHT A-1 monoblock power amps (Display) Now10
NHT A-1 monoblock power amps (Display) P3281510
NHT A-1 monoblock power amps (Display) P3201510
These brand new monoblocks have NEVER been powered "ON". All the time in their original packaging/Box, except once we took out one unit from its box (above picture) for taking advetisement pictures only.
NHT A-1 monoblock power amps (Display) P3231514
NHT A-1 monoblock power amps (Display) P3231513
NHT A-1 monoblock power amps (Display) P3231512
NHT A-1 monoblock power amps (Display) P3231511
NHT A-1 monoblock power amps (Display) P3231510
NHT A-1 monoblock power amps (Display) Nhta110
NHT A1
250 Watt Full-Range Mono Amplifier
NHT A-1 monoblock power amps (Display) 173329944_o NHT A-1
Powerful 250Watts RMS monoblock Hi-Fi & Home Theatre Power Amplifier
Selling a Brand New, in Factory box, NHT A-1 mono block power amplifier (1 pair/2 units).
This unit is a current model in the NHT Line. The A-1 delivers a hearty 250 watts RMS of highly musical power with a full frequency range of 20 Hz to 20 kHz. This dynamic range coupled with the space-saving 1.75" high chassis makes the A-1 a great choice for a number of applications, including home theater center, surround, and even main channels.
Product Info:
The A1 is a compact, cool-running, full-range, Class G monaural amplifier that NHT claims outputs 200 Watts RMS into 8 ohms, 250 Watts RMS into 6 ohms and 300 Watts RMS into 4 ohms. Distortion is spec'd at less than .01% from 20Hz-1kHz, and less than .075% distortion 1kHz-20kHz at full power.
Power on Demand: The Class G design gives you better efficiency and cooler operation than many other amplifier designs along with wide dynamic range and low distortion. Because this design supplies "power on demand", it runs cooler than many other types of amplifiers.
The A-1 both differential balanced and unbalanced (XLR and RCA ) inputs for simple connection with all types of receivers and other audio components. The balanced connections give you the best possible sound quality when used with compatible components.
NHT A-1 monoblock power amps (Display) 185629168_o
  • Designed and Engineered in the U.S.A.
  • The NHT A1 amplifier is a REAL separate chassis stand alone full range 250 watts RMS high quality amplifier.
  • Mono amplifier with 200 watts into 8 ohms, 250 watts into 6 ohms, 300 watts into 4 ohms.
  • Full range (20hz - 20kHz), Class G for cool operation, monaural amplifier. It is dramatically better in sound quality, actual output and reliability.
  • Controls/Features: Power, 12V/Audio trigger, 115volt/230volt switchable, soft clipping, adjustable lamp intensity.
  • Power mode options: Always on, 5-24v DC trigger, or auto-on/off mode.
  • Input connections: Balanced XLR, and unbalanced RCA.
  • Speaker terminals: 5-way binding posts.
  • Finish: Anthracite matte lacquer.
    NHT A-1 monoblock power amps (Display) 186017112_o
  • UltimateAVmag.com By Michael Fremer • December, 2006 - “... impressive bottom to top tonal balance with robust, musical bass, stomach crunching low frequency effects and what can only be described as "big sound.”
    NHT A-1 monoblock power amps (Display) 153195079_o
  • Stereophile U.S. No.1 audio critic magazine review (By John Atkinson • April, 2005 ) - “The A1's A-weighted signal/noise ratio (ref. 1W into 8 ohms) was respectable, at 82.6dB,... The A1 exceeds its specified power, delivering 216W into 8 ohms (23.3dBW), 340W into 4 ohms (22.3dBW), and 440W into 2 ohms (20.4dBW), though it heated up rapidly driving the latter load.”
NHT A-1 monoblock power amps (Display) Nhta1_10
Links: http://www.nhtuk.co.uk/nht_built_into_a1.htm
Links: http://ubb.outlawaudio.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=38;t=000009;p=0
Links for detail info:
NHT A-1 full range 250Watts RMS high quality monoblock power amplifier
Selling: RM4,800 negotiable. (Brand new unit in Original Packaging/Box)
Email: hifigeek2003@yahoo.com for any inquiry or SMS/Call Azlan 019-3464456 for an immediate response as I prefer this way to communicate with genuine potential buyer.
Visit my Lelong Store: NHT A-1 monoblock power amps (Display) Vms
26,970 visitors since 28 November 2006
View Seller's other items on eBay: NHT A-1 monoblock power amps (Display) IconsStores_16x16Sollehah's e-STORE
sollehah
sollehah
Number of posts : 211
Registration date : 2009-04-09
http://www.lelong.com.my/merchant/default.asp?userid=sollehah
