Audio Pro Level 05 Center
Post by monsterseng9999 on Sun Aug 07, 2011 4:58 pm
Type: Center speaker,
2-wy, passive radiator
Tweeter: 1" silk tweeter
Woofer: 2 x 5 1/4 " polyglass cone, shielded
Frequency range : 46-40.000 (-3dB)
Crossover frequency: 3.800 Hz
Impedance: 8 ohm
Amplifier requirement: 25-150 W
Sensitivity (1W/1M): 89dB
Dimensions:
(WxHxD mm) 464x155x250
Weight: 7,4 kg/
0166022188
rm400.00only
When deciding to buy yourself a nifty home cinema system made exactly the way you want and meeting your both aesthetic and audio demands, or simply upgrading from the common stereo to a higher number of channels for a more pleasant and immersive sonic experience, you should know that the center channel can really make the difference between good sound and great sound.
The center channel loudspeaker is one of the most important components in the surround sound array as it is used for deploying the biggest part of the dialog in movies or vocal parts in hi-def music tracks; even more, the center channel loudspeaker can partake in side-to-side audio effects thus ensuring you get a more enthralling experience with your multimedia. The Audio Pro Level 05 is one neat such speaker that will instantly raise the value of your sound gear, visually and most important, acoustically.
Built with Audio Pro proprietary drivers, the Level 05 sports a thorough magnetic shielding allowing you to place it under your TV or above it without fear of image distortions. The wooden cabinet is carefully voice-matched for perfect compatibility with the other speakers in the Level series and the internal strutting and damping materials ensure a vibration-free performance even in prolonged listening sessions or at high levels.
The driver complement is a d'Appolito array running on dual 5.25” polyglass-coned woofers with exceptional bass reproduction capabilities extending down to a very serious 46Hz bottom end, thanks to the bass reflex venting. Between these drivers a 1” silk dome tweeter has been placed, loaded in its own faceplate for better insulation against vibrations coming from the woofers; its response reaches a staggering 40,000Hz frequency,
[You must be registered and logged in to see this image.]
monsterseng9999
Club Member
Club Member
Male Number of posts: 42
Registration date: 2010-09-17
