Furutech ETP-60 Power Distributor
NEW SHIPMENT ARRIVED!
Promotional Price @ $399.00/each. UP@ $505.00/each.
Free Ambiance PCOCC+ powercord worth $180.00/1.5m each with every purchase! While Stocks Last!
Model: ETP-60
Description: Power Distributor
Specification:
VOLTAGE AC 250/125V 50/60Hz
CURRENT 15A
Outlets:6 Outlets
The e-TP60 is a sophisticated, luxuriously made power distributor that eliminates many common problems found with audio and video components caused by massively contaminated electrical power. The AC waveform becomes severely distorted by ground noise, voltage spikes and sags, high frequency power supply noise from other components in your own system, plus radiated high frequency digital noise from processors and digital interconnects. There are also distortion products at the top and bottom of the AC waveform created by switch-mode power supplies in electronic devices on the same circuit. Additionally, youfre never alone; your residential AC mains supply is shared with other apartments, homes, and businesses on the same utility transformer. Thatfs why many audio and video enthusiasts notice their systems are more enjoyable late at night or on weekends!
The beautifully crafted special grade aluminum chassis effectively shields against another common problem, RFI (Radio Frequency Interference), and a layer of Formula GC-303 blocks EMI (Electro Magnetic Interference). Internal wiring is FURUTECH ƒÊ-14 wirei14 AWGj that guarantees low resistance. Furutech Hyper Quality High Performance Receptacles are wired to the IEC AC input of the e-TP60. Receptacles feature 24k gold-plated phosphor bronze, non-magnetic conductors for stable, long lasting, optimized power transfer.
* Furutechfs Two-Stage Cryogenic and Demagnetization Alpha Process
The Final Result
The 2-Step Cryogenic and Demagnetizing Alpha Process works in tandem with other design-in features to create the most optimized AC power transfer possible. Furutechfs total awareness and devotion to detail results in a greater sense of power, dynamics, and resolution, with cleaner, blacker backgrounds and a larger, more stable soundstage, vivid tonal colors and deeper extension at both ends of the frequency range. The e-TP60 will allow the delicacy, refinement and nuance of a performance through, along with micro- and macro-dynamics that will leave you breathlessly engaged. Displays of all types will exhibit greater, sharper resolution with less ghosting, color shift, gsnowh, or vertical and horizontal lines.
Dimensions 200X130X60 mm
WEIGHT 0.94Kgs
Formula GC-303
GC-303 is a special material that Furutech layers and bonds to the interior bottom-plate of the chassis. It actually absorbs EMI (Electromagnetic Interference) generated by the internal fittings of the unit. The e-TP60E uses no other filtering besides GC-303 so AC resistance is kept to a minimum, allowing a more resolving, powerful, dynamic, and colorful performance from your components
[glow=red,2,300][size=5]WARNING: BEWARE OF IMITATION ETP-60 AVAILABLE LOCALLY! PLEASE TAKE NOTE IMITATION PRODUCT NOT MANUFACTURED BY FURUTECH JAPAN! IMITATION PRODUCT USES NON FURUTECH USA RECEPTACLES THAT ARE BLACK IN COLOR! GENUINE FURUTECH ETP-60 USES TRANSPARENT USA RECEPTACLES! LASTLY GENUINE FURUTECH ETP-60 SUPPORT LOCAL 230VAC VOLTAGE AND CARRIES A 1 YEAR WARRANTY BY MUSICLINK AV DISTRIBUTION.
Available now@
Musiclink AV Distribution
100 Beach Road, #02-46-49
Shaw Tower
Singapore 189702
Tel: 62911106
Business Hours: Mon-Sat: 12.30-8pm daily
Sun & Public Holidays: Closed
musiclinkav- Dealer\Reseller\Trader\Service Provider
- Number of posts : 209
» Furutech RTP-6N power distributor(used)
» Furutech e-TP 60/20 power distributor/conditioner (Used)
» Synergistic Research X power cord & Furutech RTP-6N power distributor (Used)
» Furutech e-TP609 NCF AC Power Distributor
» Furutech E-TP60 AC Power Distributor
