Blue Horizon Clean It Solution (New)
The mission of Blue Horizon is to provide class-leading products that enhance the performance of audio components, thereby maximising the end-user’s musical enjoyment.
In high-end audio, it is vital to maintain the integrity of the signal by making the best-possible connection between components. By simply removing oxidation and contaminants from cable connectors, sonic performance is significantly improved.
KEY FEATURES
-Cleans all contaminants between on sockets and connectors used in your audio system
-Safe to use on all metal surfaces
-Stabilizes similar and dissimilar metals to guarantee best possible contact and signal transfer
-Applicator brush, and cleaning cloth supplied
HOW TO USE CLEAN-IT
Using the applicator, brush Clean-IT onto every metal contact surface that is used to make an electrical connection between a cable and an audio component – that includes RCA phono connectors, speaker cable pins, spades and binding posts, headphone jacks and so on.
This may sound like overkill, but it is important to remember that all electrical connections are inherently imperfect; the connectors are machined apart and therefore will never fit exactly, a situation exacerbated by contaminants resulting from the manufacturing process. Using Clean-IT ensures that the junction between the two contact surfaces presents no barrier to electron flow and signal integrity, thereby delivering a clean and consistent path for audio signals, which in turn enhances your system’s sonic performance.
Asking for : RM 99 nett
Contract : 012-330 8893 Dicky Ng
KEY FEATURES
HOW TO USE CLEAN-IT
» Blue Horizon Pro Bubble Level Device from UK
» Blue Horizon Clean-it cleaner/protectant (New)
» Blue Horizon Clean-IT Contact Cleaner (New)
» Blue Horizon Clean IT ( Connector Cleaner )
» Blue Horizon Pro Burn ( Cable Run In )
