LC Audio RIAA MM/MC phono stage (Used) SOLD
2 posters
LC Audio RIAA phono stage mm/mc in Naim Stageline casing (casing alone RM1200 as the Naim's module are way behind this LC Audio) + separate power supply trans by promitheus, Condition 8/10. Taking any load of cartridge RM800
012-3329244 / sting@myridzwan.com
below are some info:
RIAA Phono Amplifier with MC Light Powered Step-Up.
Many modern preamplifiers are born with a poor Phono Stage - or even without a phono stage all together. Since
most audio makers don't expect their customers to use the phono amplifier, not much attention is paid to
this particular part of the amplifier. However most people who use the Phono amplifier, are serious about
it and spend large amounts of money buying a high quality cartridge and turntable. A low cost phono
stage will kill most of the details and delicacy of the expensive LP player, and therefore a high quality
RIAA amplifier module is required.
This is why we designed the Non Feedback Dual Mono RIAA Phono Amplifier with Light Powered Moving Coil
Step up. It is designed in 2003, using only opamps from renowned Analog Devices, we ensure the highest
possible sound quality. RIAA correction is passive (meaning a RIAA network shorts the filtered signals to
GND directly). The module contains 2 separate channels, so it can run as a dual mono configuration or a
normal stereo configuration.
Use of the MC step up is optional, and this section is a clone of the famous 1970's step up, that
transforms the currents from the cartridge coil, rather than the traditional way, where the voltage from
the pick-up is bled through resistors, and then amplified. The transformation method used in this MC
step-up ensures the lowest possible noise floor, and does not call for load impedance adjustments, like
the cheaper MC amplifiers found on the market. The special thing about this MC stage is that it does not
run on regular + and - power, but rather a series of small power producing photo cells produce the
necessary power to run the amplifier stage completely isolated from the power supply.
The special light supply setup for the discrete current-to-voltage transformer is
shown on this schematic of the MC step up section. Click to enlarge graphic.
This module is intended to build into a preamplifier, the LP player or a separate box, mounted away from
the required 12V power supplies (plus and minus). This is to avoid transformer hum from entering the
delicate ultra low signal amplification circuits.
In the input of the amplifier one single DC blocking capacitor (100nF Polypropylene) is found, apart from
this the amplifier is completely DC coupled. The modest use of DC blocking caps ensures the highest
degree of sonic clarity and highest level of details.
Click to enlarge photo.
Product | Price in EUR excl VAT | Ordering | Stock |
RIAA 2003 MM/MC Amplifier module w/Light Supply | EUR 231.49 | Order Now | In Stock |
Low Noise DC regulator incl. toroid transformer | EUR 53.73 | Order Now | In Stock |
Taking DIY to the next level! |
One of the most important features of a high quality RIAA phono amplifier, is low noise. In quiet
passages of the LP no noise should be allowed to reach the listener. Total silence is possible, and should
therefore be given to the user of the best available phono amplifiers. In our phono amplifier we use low
noise op-amps, from one of the worlds best manufacturers, Analog Devices. The lowest noise op-amps in the
world have something like 0,9nV/sqrt Hz, this is very low noise, and equivalent of the noise from
molecular thermal movements in a 75 Ohms resistor. However this is a spec for voltage noise, and can only
be maintained at low input impedances. (The resistance that loads the input of the amplifier). At high
input impedances like the phono cartridge 47k, (or DC resistance of some 10k), another noise spec takes
over the scene, the Input Current Noise spec. Current noise of the lowest Voltage noise op-amp is some 2
pA/sqrt Hz. (Pico Ampere per sqrt Hz). At 47k input impedance the resulting voltage noise is 2 pA x
47.000 or 94.000 pV = 94 nV / sqrt Hz. So you see when the 94 nV is added, the 0,9 nV we just paid good
money for is not to much use.
Therefore we used the op-amp with the world's lowest noise at high impedances like 10 - 47k. AD743 has 2,9
nV / sqrt Hz, (a bit higher than the lowest possible 0,9 nV) but only 7 fA / sqrt Hz. At 47k impedance
the current noise only contributes 329 pV / sqrt Hz, so still the low voltage noise is the main noise
contributor, but it is very, very low noise.
RIAA 2003 is 2 100% separate channels, and able to run in either Dual Mono setups or as a normal stereo
setup. If you use the stereo setup, you can short the three solder bubbles to link the power supplies
together. The output terminals are placed conveniently to connect to our Line Preamp mainboards.
Assembly.
The module is assembled and tested at time of delivery, so you are sure to get an instantly working
result.
Click to enlarge photo. The RIAA network is a passive network, current controlled with
the AD844 compensation pin. This ensures optimized noise performance, and NO feedback loops in this part
of the circuit!
Technical Data.
Signal / noise ratio | 88 dB (A) 47k |
Distortion THD | <0,1% 20-20.000 Hz |
Frequency Response | 16-100.000 Hz ( Inverse RIAA correction ) |
DC offset out (max) | 1 mV |
Power Supply | +/- 12 - 17 V |
Supply Current | + 40 mA - 30 mA |
Supply Current MC Stage | 12V 80 mA |
Re: LC Audio RIAA MM/MC phono stage (Used) SOLD
is there any loading switch for MM ?
wabun- Frequent Contributor
- Number of posts : 423
Registration date : 2009-03-02
Source(s): Mac mini - Bryston BDP - Calyx DAC 24/192 - Rega P8
Amplification: Jumpan Balance - ARC VT100Mk3 - Musical Fidelity FX
Speakers: JBL 4313B , Harbeth P3esr
No loading as it reads the current from your cartridge. I've been using with 0.25mv MC cartridge with excellent dynamic & drive
» Audio Note M5 RIAA phono stage(used) SOLD
» Audio Note M1 RIAA Tube Phono Stage (Used) SOLD
» Graham Slee Fanfare Amp-3 Moving Coil RIAA phono stage SOLD
» Withdrawn: Croft Acoustics RIAA RS Valve / Tube Phono Stage Amplifier * Made In England
