Electronic Crossover ???
2 posters
Hi, anyone know much about electronic crossover ? is it make sense to split the music to low, mid and high and use different amp to drive woofer, tweeter separately ? any advantage over the conventional bi-wiring / bi-amp ?
wabun- Frequent Contributor
- Number of posts : 423
Registration date : 2009-03-02
Source(s): Mac mini - Bryston BDP - Calyx DAC 24/192 - Rega P8
Amplification: Jumpan Balance - ARC VT100Mk3 - Musical Fidelity FX
Speakers: JBL 4313B , Harbeth P3esr
Re: Electronic Crossover ???
Hi wabun,
I own a electronic crossover model Behringer ULTRADRIVE PRO DCX2496. yes, it can mix the frequency which you like (3 input & 6 output).
You can use it for stereo input to (Right-Hi,Mid,Low & Left-Hi,Mid,Low) 6 output. Every individual output can be calibrate as your require
You also can set it as 3 channel input (Right,Left & mono sub) to (Right Hi,Mi-Low Left Hi,Mid-Low & Sub bass)
You can refer to the manual start from page22
http://www.behringerdownload.de/DCX2496/DCX2496_ENG_Rev_B.pdf
The only problems for this unit is you require to DIY some cables,
if you are using preamp for stereo input to 3 units of stereo power amp the cables you require as below
RCA to XLR female x 2nos
XLR male to RCA/XLR x 6nos
To set up the crossover, one must have some frequency knowledge example
what is Mhz @ Khz for treble, midrange, midbass, lowbass. (also what is
the frequency for vocal, dram, guitar, and most comment music equipment
use)
The sound quality is very depent on your calibrition skill. Neverteless, this is the fun unit to explore.
Some one is selling this unit as below:
https://www.hifi4sale.net/audio-video-equipment-for-sale-f1/behringer-dcx2496-ultra-drive-pro-crossover-new-t713.htm?highlight=ultradrive+pro+dcx2496
Good Luck.
use)
Good Luck.
Chewkw- Frequent Contributor
- Number of posts : 192
Source(s): Naim CDS II
Amplification: Naim NAC52/NAP135
Speakers: Naim SBL
Hi,
I come across this thought after reading an old magazine bout electronic crossover, the article said " it is ultimate solution in Hifi"
yet after visit hifi shop and listen to an Avant Garde.. which using
electronic corss over, dissaponited...
» Accuphase F5 Electronic Crossover
» WTS Kicker 3-Way Electronic Crossover KX3
» Sublime K231 Electronic Crossover
» sansui cd-10 electronic crossover SOLD
» Naim Electronic Crossover Snaxo (sold)
