Carver AV-505 5-Chan Power Amp & Carver CT-26v Pre-Amp System(Used)
HiFi System for Sales, price nego.
Reason: Seldom listen
COD: KL/Selangor
Contact: iteck2@yahoo.com
Remarks: Well take care, please feel free to contact me if you need more pictures
Complete Set: RM3,500 Only
Carver AV-505 Five Channels Power Amplifier (can be used for Home Theater System)
Condition: Used (8/10)
Voltage: 110V
Detailed Specifications:
One compact amplifier provides all the power needed for a high performance home theatre system
Total Direct Coupling for high damping factor at all frequencies
Each channel protected by: individual fusing, excess temperature sense, DC fault sense, power-on delay, shorted load sense.
Minimal signal path design, with on card I/O connectors eliminating internal interconnect cables
Gold Plated RCA Jack Connections
Individual calibrated level trim controls for each channel
Removable handles for 17 cabinet space (with trim caps)
Designed and built by Carver Corporation in Lynnwood, WA USA
Frequency Repsonse: 20-20kHz +0,-0.2dB
Power Output: FTC 20hz-20khz
8ohm 100 watts per channel two channels driven
8ohm 80 watts per channel all channels driven
THD: less than 0.08%
Dynamic Headroom: >1.1dB @ 8ohms all channels driven
Gain: 29.0 dB (+/- 0.5dB)
Input Impedance 50 kohms
Damping Factor: >300 typical (20hz-20 khz)
Carver CT-26v Preamplifier (can be used for Home Theater System)
Voltage: 110V
This Carver CT-26v is in excellent 100% full function condition.
The CT-26v is a high performance control center designed with the experience and knowledge of a long line of quality Carver separates. In addition to Dolby Pro Logic® surround sound with adjustable delay and five surround modes, the preamp/tuner design incorporates Carvers exclusive SFX technology, which expands the critical rear soundstage beyond the confines of the listening room. The features offered by the CT-26v were carefully selected to provide the flexibility required for a surround sound system, but not so complicated to make it difficult to understand and operate. This preamp/tuner will provide uncompromising audio performance from every channel.
NAD 512 CD Player
Condition: Used (6/10)
Voltage: 110V
Note: Need to repair, but repairable
Paradigm Studio 20 v1
Condition: Used (7.5/10)
FOC: Speaker Stand
Kimber Kable 4PR Speaker Cables (w connector spade and banana plug)- 1m
Condition: Used (8.5/10)
Kimber Kable 4PR Features:
Four brown and four black braided conductors
2 x 14awg/2.08mm
High-purity copper
Special formula PE dielectric
Kimber Kable 4PR Technical Specifications
Parallel capacitance: 312pF @ 20kHz
Series inductance: 0.654H @ 20kHz
DC loop resistance: 0.041Ω
Total reactance: 0.0825Ω @ 20kHz
Frequency response: 0.5dB - 100kHz
COD: KL/Selangor
Voltage: 110V
Voltage: 110V
NAD 512 CD Player
Voltage: 110V
FOC: Speaker Stand
2 x 14awg/2.08mm
High-purity copper
iteck- New Member
- Number of posts : 2
» Carver AV-505 5-Chan Power Amp & Carver CT-26v Pre-Amp System(Used)
» Carver AV-405 power amplifier (used)
» Carver Power Amp
» Carver Pre and Power Amplifier
» Carver Pre & Power Amp (Used)
» Carver Power Amp
