WTS: PSB Alpha B1 BookShlf Speaker And Alpha CLR1 Center Speaker
2 posters
Frequency Response: On Axis @ 0-degrees, +/-3dB, 90-21,000 Hz; Off Axis @ 30-degrees, +/-3dB, 90-10,000 Hz; Lf Cutoff -10dB, 80Hz
Sensitivity (1w (2.83V) @ 1m, IEC-filtered Pink Noise, C-weighted): Anechoic Chamber, 86 dB; Typical Listening Room, 88 dB
Impedance: Nominal, 6 Ohms; Minimum, 4 Ohms
Input Power (RMS,Clipping < 10% of the Time): Recommended, 15-80 Watts; Program, 60 Watts
Crossover: 3,000 Hz, B3
Dimensions: 9-3/4" wide, 4-1/4" high, 6-1/4" deep
Weight: 4.8 lb each
Name : PSB Alpha CLR1
Condition: 9/10
Price:RM300
SMS:012-3934810
Frequency Response: On Axis @ 0-degrees, +/-3dB, 65-21,000 Hz; Off Axis @ 30-degrees, +/-1.5dB, 65-10,000 Hz; Lf Cutoff -10dB, 55Hz
Sensitivity (1w (2.83V) @ 1m, IEC-filtered Pink Noise, C-weighted): Anechoic Chamber, 89 dB; Typical Listening Room, 91 dB
Internal Volume Design Type: 0.29 cu ft (8.0 liter)
Dimensions: 7-1/16" wide, 11-7/8" high, 9-1/2" deep
Weight: 8.8 lb each
Name: PSB Alpha B1 Bookshelf Speaker
Condition:9/10
Price: rm680
sms:012-3934810
Weight: 4.8 lb each
Condition: 9/10
Price:RM300
SMS:012-3934810
Weight: 8.8 lb each
Condition:9/10
Price: rm680
sms:012-3934810
hinoyhk- Dealer\Reseller\Trader\Service Provider
- Number of posts : 51
Registration date : 2011-06-10
Re: WTS: PSB Alpha B1 BookShlf Speaker And Alpha CLR1 Center Speaker
Why sms no answer?? Still intrested to sell or not? Or still not decided to sell.....
hoyhoysum- Frequent Contributor
- Number of posts : 241
Source(s): Grundig 2070, Graetz Sinfonia Spizensuper 522, Saba Freiburg 14, Normende Phono Super V700
is....which 1 u want??
» PSB Alpha Series CLR1 center speaker (used)
» PSB Alpha CLR1(Used)(SOLD)
» PSB Alpha CLR1 Speakers (SOLD)
» PSB Alpha center speaker (Used) Sold
» PSB Alpha C1 Center Speaker [SOLD]
