Ways to remove tight and rusty screw
+7
david&david
WongKK
bal
cyh
cmboy
elhefe
public holiday
11 posters
What is the best way to remove tight and rusty screw?
public holiday- Club Member
- Number of posts : 46
Registration date : 2009-11-24
Re: Ways to remove tight and rusty screw
Try WD40.
_________________
elhefe- Moderator
- Number of posts : 1371
Remove from what? hifi equipment? some machine? some what?
There's various methods of removing stuck fasteners. WD40 isn't always the last word or the means to an end. Its only an aid for easier problems.
If some of you have watched one Astro program, Kings of Restoration, one frequent method is applying heat to rusted fasteners to remove it effectively and surely.
Kindly provide more details if you require specific advice.
cmboy- Frequent Contributor
- Number of posts : 1298
Try KY jelly
cyh- Frequent Contributor
- Number of posts : 326
cyh wrote:Try KY jelly
You live dangerously dude
_________________
elhefe- Moderator
It should help a tight and rusty screw though....
bal...
bal...
bal- Moderator
- Number of posts : 1275
Speakers: maggie 1.7
Ok remove from speakers, wanted to replace those rusted screw but too tight to remove. Penetrating oil like WD-40 didn't work
If the screw is screwed into metal, you could heat it up, get the metal to expand, and get it out. A few heat/cool cycles should help. But if it is screwed into wood, then you don't have this option.
I suppose the remaining option is to drill out the screw.
WongKK- Frequent Contributor
- Number of posts : 149
What about impact driver?
Start gently....use a vibrator
david&david- Club Member
Registration date : 2011-09-03
Care to explain more?
A proper recommendation would be best if there's a picture of the actual problem. Worst case is to carefully grind it off with a hand grinder or Dremel tool, if available. Then find and fit new fasteners.
this is it i got it online, the real condition the screw is rusted but the head is strong not stripped yet.
That is a socket screw, ita should be able to unscrew with soem force. U can still apply wd40, but very minimum, dont let it soak too much into the wood. After the wd40, wait 5 min, then use soem force to unscrew it.
If the hex head socket is completely loose. U ned to do grinding or drilling to get rid of the head. Not easy job, if u r not diy inclined, get soemone with good enough skill to do itq. As it is very easy to accidentally poke a hole into the driver, if u r not careful enough.
- Number of posts : 722
I feel the best is using battery drill with minimum force. This will give you the vibration to unscrew it. Also make sure your drilling key bit is actual size to prevent damaging the screw head.
Chewkw- Frequent Contributor
- Number of posts : 192
Source(s): Naim CDS II
Amplification: Naim NAC52/NAP135
Speakers: Naim SBL
I tried WD 40 but it didn't work at all, i used allen key screw with exact size for the head. Where can i find the service with impact driver or battery drill?
Mr. Public Holiday,
Never, never use a grinder near a speaker, the flying debris will be attracted by the powerful magnet and instantly kill any speaker.
I would suggest:
1) get a strainght type of exact size hexagonal Allen Key and insert
into the stuck screw. Use a small size hammer, knock lightly
several times with extreme care.
2) spray CRC 5.6 or WD 40 sparingly into the side of the shaft of the
stuck screw. Leave it for about 15 min.
3) now, replace with a L-shape Allen Key, turn it a bare hand about
1/4 turn clockwise, slowly with extreme care.
You may now attempt to turn it anti-clockwise lightly, if that
failed, repeat the same as Item 1) and 2)
4) Never try hard to turn a stuck screw, it may break its head, and
you are going to have hard time to remove the broken shaft.
I would suggest:
chewkwokhon- Frequent Contributor
- Number of posts : 318
Registration date : 2009-05-19
Ain't working man
You can try using ezy out. It's works most of the time.
7810sam- Regular
- Number of posts : 99
Registration date : 2009-10-06
» Air tight ATM 300 used
» Air Tight ATC-2 preamp (used)
» Air Tight ATC-2 preamp (Used)
» Air Tight ATM-1S power amplifier (Sold)
» Air Tight PC-1 Supreme MC Cartridge (Withdrawn)
