jolida jd 9 phonostage
3 posters
Hi friends, brand new jd 9 is available for order at s$618 all in. For limited time only. For more info please visit [You must be registered and logged in to see this link.] thanks!
Thanks for viewing, cheers!
Hi5LOFT crew
Hi5LOFT crew
Re: jolida jd 9 phonostage
Please follow the guideline... No need FS in title.
_________________
elhefe- Moderator
- Number of posts : 1371
Upz
TECHNICAL SPECIFICATIONS
Tubes components :
12AX7 x 2
Gain :
MM: 60 dB, 5 mV
MC Low: 75 dB, 0.5 mV – 1.5 mV
MC High: 80 dB, 0.25 mV – 0.5 mV
Bandwidth :
10Hz - 10KHz at +/-db
Signal to noise ratio :
>100db
THD :
<0.02%
Input impedance
variable by DIP switch, 100 ohm, 300 Ohm, 1Kohm, 47Kohm
Input capacitance
variable by DIP switch, 47pf, 100pf, 150pf, 220pf
Number of inputs
4 RCA
Number of outputs
2 RCA
Size in inches
17 in. (W) x 13 in. (D) x 2 in. (H)
Size in mm
430(W) x 390 (D) x 105 (H)
Weight in pounds
10 lbs., 14 lbs. Boxes
Tubes components :
12AX7 x 2
Gain :
MM: 60 dB, 5 mV
Bandwidth :
>100db
THD :
<0.02%
Input impedance
Input capacitance
Number of inputs
4 RCA
Number of outputs
2 RCA
Size in inches
Size in mm
Weight in pounds
Price increasing soon
Hi fellow analogue lovers,
Last chance to own this jd9 at this promotional price, all orders before 25th jun will be at s$618, thereafter the price will be going at $699. That's applies to all Jolida ranage of products, as the inflation rate in china has increased the cost of the equipment.
Please be think and act fast.
Cheers, HI5LOFT Crew
A very very good phono stage, we have upgraded version in jd9se1 using high end component and op37, don't miss it!
pls advice what phono pre-amps available now?
thks
thks
boxer- Frequent Contributor
- Number of posts : 628
Hello, I am not sure what is your question. Pls send me an email at [You must be registered and logged in to see this link.] for further discussion, cheers
eg. jd9 now is which revision available? any other phonostage models available from jolida? also pls let me know the prices...thkshi5loft wrote:Hello, I am not sure what is your question. Pls send me an email at [You must be registered and logged in to see this link.] for further discussion, cheers
pls quote the price.
thks
thks
If pick up in sg?
Can..jd9 is $699
Would you consider a tube preamp with phono? We have a demo set for sales at $1500
» Fs jolida jd9 se3
» Jolida Foz XT-R
» Jolida JD 200 tube CD player
» Jolida Fusion DAC Transport (New)
» Jolida JD 9A Phono Stage
» Jolida Foz XT-R
