Audio-Gd Compass DAC / Pre-Amp / Head-Amp (Sold)
2 posters
Up for grabs today is a stock Audio-Gd Compass DAC / Pre-amp / fully discrete head-amp in great condition. The Compass sports various settings that can be configured to suit your listening preferences. This Compass is a no-nonsense combo – check out its guts:
Motorola Fast type diodes
No coupling caps in the signal pathways
All 1% tolerance Vishay/Dale resistors - matched pairs in signal pathways. Generic good quality resistors - metal film/metal oxide types.
Full discrete topology in analog amplifier stage and DAC output stage (user swappable modules)
Copper billet 24K gold plated RCA jacks
Neutrik 1/4 inch Locking Headphone jack
Analog Devices AD1852 Digital to Analog converter IC - 24/192 KHz capable
Renowned DIR9001 low-jitter digital input receiver
Burr Brown/ Texas Instrument PCM2707 IC used for USB input
Dedicated transistor regulated power supply
Low Phase Distortion analog filtering - DAC
Matched Toshiba & Hitachi transistors
Alps RK27 50Kohm volume pot
Alps power switch and input selector
Evox (Rifa) film caps
NoVer Electrolytic caps - UK made, Audio Grade.
Fully shielded 50 Watt Toroidal transformer
Rectifier PCB installed separately from power supply - part of shielded transformer assembly.
PCB construction - 2 mm double sided gold plated through hole type. 70uM copper.
13,200 uf of mains filtering capacitance. NoVer Audio Grade RX11 (3,300 uf x 4)
Ground loop breaker circuit - 2 diodes 1 resistor.
The pre-amp module can be switched on / off via a switch at the back. A similar switch also controls the gain settings. The Compass comes with the Earth HDAM module, stock optical cable, stock USB cable, stock jumpers and stock power cable. You can buy additional HDAM modules (Sun and Moon) directly from Audio-GD if you want to. If you’re a hardcore DIY kinda guy, you can modify / customize the Compass and take it a step further on what is already a darn good platform.
For the curious, this unit belongs to my uncle who has since upped the ante with his purchase of a Lavry DA11. A 60-year old guy isn’t going to be bothered with composing ads online so yeah, you can say that I’m his b**ch and no, I don’t get a cut from this sale. He’s family man! What were you thinking?
Some reviews:
http://www.head-fi.org/t/385759/the-audio-gd-compass-was-designing-an-alternative-to-the-zero-dac-amp/3195#post_5452809 – Compass reviewed against Meier Corda Opera
http://www.head-fi.org/t/385759/the-audio-gd-compass-was-designing-an-alternative-to-the-zero-dac-amp - very long thread – from prototype to final release.
Pictures section:
Front - https://i.servimg.com/u/f44/14/24/19/07/front11.jpg
Back - https://i.servimg.com/u/f44/14/24/19/07/back110.jpg
Back 2 - https://i.servimg.com/u/f44/14/24/19/07/back210.jpg
Internal - https://i.servimg.com/u/f44/14/24/19/07/int110.jpg
Caps shot - https://i.servimg.com/u/f44/14/24/19/07/int210.jpg
*Feet shown in the pictures are NOT included. Those are mine as I’m testing out the Compass in my rig.
Price: Sold
Condition: I always rate 7/10 for used gears regardless of how well kept they are
Age: 2 years
Will be able to do COD in Kulim, Bukit Mertajam, Butterworth. I will use Poslaju / Skynet for other areas. Additional courier charges will apply.
Contact: etteoh@gmail.com (email) or PM
Some reviews:
Pictures section:
Price: Sold
Age: 2 years
Last edited by etteoh on Sun May 06, 2012 12:37 pm; edited 4 times in total (Reason for editing : Item sold)
etteoh- Regular
- Number of posts : 73
runemaster- Regular
- Number of posts : 99
Registration date : 2009-09-23
etteoh- Regular
» Audio-Gd Compass (SOLD)
» Audio-GD Compass DAC (SOLD)
» Audio-Gd Compass DAC (SOLD)
» USHER Compass X-719 (SOLD)
» Audio-gd Compass (Used)
