PSB Image Subsonic 6 Powered Subwoofer 12 inch (sold)
PSB Image Subsonic 6 Powered Subwoofer 12 inch (sold) Empty PSB Image Subsonic 6 Powered Subwoofer 12 inch (sold)
Post by HiFiLab Mon May 07, 2012 12:33 am
PSB Image Subsonic 6 Powered Subwoofer 12 inch (sold) P1120420
PSB Image Subsonic 6 Powered Subwoofer 12 inch (sold) P1120421
PSB Image Subsonic 6 Powered Subwoofer 12 inch (sold) P1120422
FREQUENCY RANGE (Anechoic Chamber)
Response
On Axis @ 0° ±3 dB 25-150Hz
LF Cutoff (-10 dB) 20Hz
SOUND
PRESSURE LEVEL
Maximum @ 100Hz 110 dB
SENSITIVITY*
Anechoic Chamber 92 dB
Listening Room 94 dB
IMPEDANCE
Nominal 4 Ohms
Minimum 4 Ohms
AMPLIFIER POWER
Continuous 130 Watts
Dynamic 220 W
Dynamic Peak 440 W
Design Class AB
ACOUSTIC DESIGN
Woofer 12" (305mm)
Poly-coated Fiber Cone
Foam Surround
2" Voice-Coil
Crossover Variable 50Hz-150Hz
LR4
Internal Volume 1.64 cu ft (45.9 liter)
Design Type Bass Reflex
2 x 2" Front Port
SIZE (W x H x D) 15"x19.37"x14.25"
381 x 492 x 362mm
WEIGHT
Net 44 lbs (20.0Kg)/each
FEATURES
Controls Volume, Crossover,
Phase, On/Off,
Standby/Auto On
Connections LL /LFE In&Outputs,
High Level Input and Output
Gold-plated RCAs,
5-way Binding Posts,
Other High Pass Filters
Horizontal or Vertical,
Feet
Condition 8/10
Price : RM1350
Contact Simon Ting 012-3612507[code]
Last edited by HiFiLab on Mon May 28, 2012 1:42 pm; edited 1 time in total (Reason for editing : sold)
HiFiLab
Number of posts : 2967
