B&W Rock Solid Solutions S-100 speakers (Used)
B&W Rock Solid Solutions S-100 speakers (Used) Empty B&W Rock Solid Solutions S-100 speakers (Used)
Post by sollehah Sun Aug 09, 2009 3:23 am
B&W Rock Solid Solutions S-100 speakers (Used) Bwrock10
Feed your passion
  • Listen and be ABSORBED
  • Listen and be INTOXICATED
  • Listen and be RELEASED
  • can lift your spirits
  • can heal the pain
  • Listen and you'll see...
B&W Rock Solid Solutions S-100 speakers (Used) Bwlogo10 B&W Loudspeaker Ltd. produces the BEST SPEAKERS in the world.
B&W Rock Solid Solutions S-100 speakers (Used) 292673791_o
B&W BOWERS & WILKINS ROCK SOLID SPEAKERS S-100 WHITE for Hi-FI & Home Theatre
B&W Rock Solid Solutions S-100 speakers (Used) 101033335_o
This is a very nice example of a pair of Rock Solid Solutions S-100 speakers. Solid speakers are manufactured by B&W (Bowers & Wilkins), England.
The speakers are white in color, and are in very clean condition. Sound and perform great as well. The magnetically shielded speakers deliver a full, rich sound, and are rated at 75 Watts 8 Ohms.
These speakers are able to be corner mounted (Wall mounting brackets are included).
They sound great for 2-channel music.
You could also use them as surround Rear Speakers for Home Theatre set-up.
B&W Rock Solid Solutions S-100 speakers (Used) 101033373_o
PRODUCT DESCRIPTION
This versatile but powerful stereo speaker has been stylishly designed with B&W Loudspeaker Limited (England) for the acoustical engineering of high quality monitor speaker to ensure the maximum sound quality. It has been designed for use in any room in the house - with its multipurpose wall bracket it can be mounted either way up in corners or flat on walls; or on a table; or on a speaker stand.
The ROCK SOLID S-100's gently curving front baffle design minimises unwanted diffraction and the fully moulded cabinet reduces troublesome internal cabinet resonances. B&W's renowned expertise has resulted in an exceptionally smooth-sounding unit giving remarkable detail for all time music/stereo enjoyment.
B&W Rock Solid Solutions S-100 speakers (Used) 292655173_o
B&W Rock Solid Solutions S-100 speakers (Used) Bowersandwilkins
B&W Rock Solid Solutions S-100 speakers (Used) 292655226_o
SPECIFICATIONS
Description
2-way 4th-order vented box system
Drive Units
1x 100 (4in) bass/mid
1x 25mm (1in) high-frequency
Frequency Response
95Hz-20kHz +-33dB on reference axis
Sensitivity
89dB spl (2.83V, 1m)
Nominal Impedence
8 ohm
Crossover Frequency
3.5kHz
Recommended amplifier power
Up to 100W continuous into 8 ohm on unclipped program
Protection
Polyswitch
Dimensions
Height: 258mm (10 1/8 in)
Width: 207mm (8 1/8 in)
Depth: 90mm (3 1/2 in)
Net Weight
1.5kg (3.3 lb)
Finishes
Black or White
Check out http://www.audiorevolution.com/equip/rocksolid/index.htm
for a review. Thanks for looking
Rock Solid Solutions Speaker System B&W Rock Solid Solutions S-100 speakers (Used) Bwrock10
Written by Kim Wilson, audio video REVOLUTION
B&W Rock Solid Solutions S-100 speakers (Used) 292673753_o
"If you haven't gotten into 5.1 audio because you're waiting for a simple and inexpensive approach to the multi-speaker dilemma, then you should take a listen to Rock Solid's Solutions 100 system.
Using a Philips/Magnavox DVD400AT DVD player I put the Rock Solids to the test using the special effects laden movies, GoldenEye and Desperado. I was impressed by how well these small speakers handled dynamic range. The overall ambient coverage was very good, providing a realistic and effective surround field.
While the Solutions 100 is tuned specifically for home theater use, no doubt, the system will be used for playback of audio CD's on occasion.
..., the Solutions 100 does provide a spacious and effective delivery of 5.1 audio soundtracks in a sleekly designed package.
The Rock Solid Solutions 100 speaker package... would be an ideal entry level home theater or even a second system for any dent, bedroom or recreation room."
B&W Rock Solid Solutions S-100 speakers (Used) 290400433_o
B&W Rock Solid Solutions S-100 speakers (Used) Bwsoll10
B&W Rock Solid Solutions S-100 speakers (Used) 266430955_o Made in England
Links:
B&W Bowers & Wilkins ROCK SOLID SPEAKER S-100 for Hi-Fi & Home Theatre
Selling: RM950.
Seller's Preference: Email me hifigeek2003@yahoo.com or SMS/Call Azlan 019-3464456 for an immediate response.
Visit my Lelong Store: B&W Rock Solid Solutions S-100 speakers (Used) Vms
27,840 visitors since 28 November 2006
View Seller's other items on eBay: B&W Rock Solid Solutions S-100 speakers (Used) IconsStores_16x16Sollehah's e-STORE
sollehah
sollehah
Number of posts : 211
Registration date : 2009-04-09
http://www.lelong.com.my/merchant/default.asp?userid=sollehah
