Meixing MC2A3-07 Tube Integrated / Power Amplifier Mono Blocks (New)
FEATURES:
Integrated / power amplifier dual function
Heavy duty Stainless steel and alloy plate construction
Custom built audio and power transformers using:
Zll and H18 long grain annealed and directed steel sheets
Hand built with all hand welding internal connections
USA made Teflon silver cable for audio signal paths
Gold plated tube sockets and gold plated adjustable supports
Class A push pull circuit
High-end choke power supply plus CLC fitering
274B vacuum tube rectification
Typical full 2A3 / 300B tube fantasy sound with good dynamics
Either 2A3 / 300B vacuum tubes can be used in this model by simply shift the selection switch
Deadly silent background, transparent and full of musical expressions
Detachable power cord system (IEC)
TECHNICAL:
Output Power: 15W x 2 (2A3)
Output Load Impedance: 4ohms, 8ohms
Input Sensitivity: 320mV (as integrated amplifiers)
1000mV (as power amplifiers)
Power Consumption: 90W
Frequency Response: 10Hz - 46kHz, +/-1%
Vacuum Tubes (per unit): PSVAVE 2A3 x 2,
Electroharmonix 6H30 x 1,
6922 x 1, 274B (Rectifying tube) x 1
THD+N: <0.5% (1Khz)
S/N ratio: ≥ 90db
Dimensions (L x W x H) per block : 43 x 31.5 x 20 cm
Price RM4980.
Call 012-4937380 for further details.
Check out our Blog for other audio products :
http://theartchamber.pixnet.net/blog
wflee- Dealer\Reseller\Trader\Service Provider
- Number of posts : 425
Registration date : 2009-03-12
» Meixing MC2A3-07 Tube Integrated / Power Amplifier Mono Blocks (New)
» Copland CTA 520 Power Amplifier / Mono-blocks (SOLD)
» Leak TL/12 Plus Tube Mono Blocks Power Amp (Used) SOLD
» Copland CTA 520 Power Amplifier / Mono-blocks (Used)
