Cambridge Audio DAC Magic Plus (New)
Improving on a legend is never easy, but Cambridge Audio has gone back to the drawing board to create the DacMagic Plus with exciting new features, wireless device connectivity, and best of all, significantly enhanced audio performance.
We live in a world of immense musical opportunity. Computers, TVs and Blu-ray players can all deliver audio to your hi-fi system, but because they’re primarily designed to perform other functions, their audio outputs lack quality. But by simply connecting them to DacMagic Plus, you can bypass their inbuilt digital to analogue converters transforming their humdrum performance into something altogether more spectacular!
DacMagic Plus works by taking a digital audio signal from your PC, digital iPod dock or TV which it analyses and upgrades using our clever ATF2 algorithm. It’s totally flexible and supports digital music of all formats. DacMagic Plus even supports 24-bit data over USB so you can enjoy better than CD quality from uncompressed music stored on your PC.
~Twin Wolfson WM8740 24bit DACs used in dual differential configuration.
~New Anagram Technologies ATF2™ 24-bit/384kHz audio up-sampling / jitter reduction.
~Optional Digital Preamp mode allowing connection directly to power amp or active speakers.
~24-bit/96kHz driverless USB Audio 1.0.
~24-bit/192kHz USB Audio 2.0 with ASIO or kernel streaming modes.
~Asynchronous USB transfer for very low jitter.
~Selectable digital filters - linear phase, minimum phase and steep.
~Balanced XLR audio output and RCA phono output.
~Two 24 bit digital inputs (with optical or coaxial for each).
~External input for optional BT100 Bluetooth receiver - allows audio to be streamed and up- sampled from any paired Bluetooth device.
~Supports high quality apt-X Bluetooth CODEC as well as standard SBC Bluetooth CODEC.
Selling Price : RM 2150 (Call For Best Price)
________________
Best regard
Steve Chua
6012-6535703
603-77266893
CMY Audio & Visual Sdn. Bhd.
S336, 2nd Floor,
1 Utama Shopping Centre,
(New Wing) Bandar Utama,
47800 Petaling Jaya
» Cambridge Audio DAC Magic
» cambridge audio dac magic
» Cambridge Audio DAC Magic (Used)
» WTS: Cambridge Audio DAC Magic (Used)
