Amplifier recommendations RM 2500-3000
Page 1 of 1 • Share •
Hi Sifu
Just want to ask, what is the best amp around that price?
microkernel- Regular
Number of posts: 65
Registration date: 2009-06-21
Source(s): Dacmagic, iPod, CD5i
Amplification: Naim Nait XS
Speakers: Dynaudio DM 2/7
Re: Amplifier recommendations RM 2500-3000
what speakers r u using ?
what kind of music do u like to listen to?
Are you a CD, LP or MP3 person ?
Whats your listening environment?
Consider this phrase: "If you don't know where you are going, any road will take you there".
Apply it to hifi, & the analogy would be: "...any amp will satisfy you"
Number of posts: 2665
Registration date: 2009-04-04
Source(s): Marantz
Amplification: Exposure
Speakers: Harbeth P3ESR
ha ha ... couldn't agree more. And if it's just a car to take you from Point A to Point B, anything will do.
Microkernel - "Best" is relative. Your ancillaries and choice of music play a part, too. Getting the "best" of each and putting them all together will not necessarily mean you're going to get the "best" sounding system for the price. They need to work together.
bassraptor- Moderator
Number of posts: 727
Registration date: 2009-01-17
Source(s): LP/CD/Streamer
Amplification: Yes
Speakers: Yes
Thanks Bro,
mugenfoo wrote:what speakers r u using ?
mordaunt-short MS 914
acoustic and rock genre
always cd and mp3, use CA dac magic connected to pc.
standard living room size
adoi, my existing amp already broken la.before this use soundstage hybrid amp
Number of posts: 65
For the price range i think you can try AudioLab 8000S, it match mordaunt short Avant and carnival series well, but i very less listen to rock, you have to try it yourself~~
skydna- Frequent Contributor
Number of posts: 119
Registration date: 2009-02-23
Source(s): Naim
Amplification: Naim
Speakers: ProAc
Now we're getting somewhere ...
yes, the Audiolab 8KS would be a good candidate.
Also try Audio Analogue Primo series ... in the same class as well. Different sound. Try as much as u can before parting with your hard earned money.
Or if u dun mind s/hand stuff, u can get something in a better class than both the Audiolab and AA Primo.
Source(s): Marantz
consider QUAD 606 s/hand, this is power amp only, so you need pre-amp also. check forum about how people rate the QUAD 606.
khwong7744- New Member
Number of posts: 15
Registration date: 2009-03-04
for my opinion, there is no such thing as a best amp. any amp is good, it is just, do you like the sound reproduced by that amp, or does the amp match the speaker. or most importantly do you like that sound, and there is no right or wrong in audio world, i believe, everything is like this and the price you pay for is worth or not depends on how satisfy you are with the equipment.
sonyman1- Club Member
Number of posts: 37
Registration date: 2009-02-20
khwong7744 wrote:consider QUAD 606 s/hand, this is power amp only, so you need pre-amp also. check forum about how people rate the QUAD 606.
Quad 606 is kinda slow and mellow sounding. Almost to the point of being a lazy amp. Not sure if it will generally suit this decade's type of music especially in the age of computer audiophiles and MP3s.
But hey, definitely do seek one out for a listen , coz who knows u might just fall in love deeply with its type of sound...
Source(s): Marantz
mugenfoo wrote:Now we're getting somewhere ...
AA Primo - I assume it is the Settanta version that is being referred here.
There are 2 generations for this 70 watter.
By the way, Settanta means 70 in Italiano.
The Primo Settanta Rev2.0 is above RM3k for a new unit.
The 1st generation should be cheaper.
Number of posts: 1056
Registration date: 2009-01-19
check out yamaha A-s1000, 90w/ch, solid state look-a-like,
latest from yamaha natural sound line up
dont ask me what it means, hehe
With the A-S2000 and now the A-S1000, Yamaha has taken the bold step of using a floating balanced configuration to update the power amplifier for serious music fans. This method, which is completely different from the pure complementary circuit that has been the main type used for the past four decades, features identical polarity on the plus and minus side of the output stage. By completely isolating the plus and minus sides of the left and right channels of both the NFB and power supplies, it achieves perfectly symmetrical operation in the output stage. The use of four sets of floating power supply units (not connected to earth), provides further operating precision. The result is very low levels of noise and distortion for exceptionally pure and transparent sound quality.
azri- Frequent Contributor
Number of posts: 1036
Registration date: 2009-01-21
hahahaha sounds like an exerpt from the Pioneer brochure. So has anyone here actually heard the Pioneer amp in action? i myself am also in the dark on thids.. coz haven't heard it before either.
Source(s): Marantz
azri wrote:check out yamaha A-s1000, 90w/ch, solid state look-a-like,
latest from yamaha natural sound line upWith the A-S2000 and now the A-S1000, Yamaha has taken the bold step of using a floating balanced configuration to update the power amplifier for serious music fans. This method, which is completely different from the pure complementary circuit that has been the main type used for the past four decades, features identical polarity on the plus and minus side of the output stage. By completely isolating the plus and minus sides of the left and right channels of both the NFB and power supplies, it achieves perfectly symmetrical operation in the output stage. The use of four sets of floating power supply units (not connected to earth), provides further operating precision. The result is very low levels of noise and distortion for exceptionally pure and transparent sound quality.
Ah yamaha S-1000 i think will be a very good choice, i did listen to S-2000 before it is warm, liquid and very musical, but not for those looking for fast and dynamic, cause my friend fall as sleep even playing michael jackson, but is sound is really relax and conformable~~
mugenfoo wrote:hahahaha sounds like an exerpt from the Pioneer brochure. So has anyone here actually heard the Pioneer amp in action? i myself am also in the dark on thids.. coz haven't heard it before either.
Pioneer A-A6-J i did listen to it before i get my amplifier, it is fast, dynamic ,accurate, but seems it has less taste for me
Source(s): Naim
Amplification: Naim
Speakers: ProAc
i enjoyed having yamaha amps, stereo amp (not avr)
it can last for a long time, mine has a pair of huge elna caps
i saw the s-1000 & i thought someone polish his old yamaha gear
& try to sell it back in one of local stores haha, but i was wrong of coz
by looking at the size, it is almost twice the size of my 760 mkII
wonder how it performs.. hmmm
Similar topics» Forum Recommendations
» ATI Radeon HD 4250 vs Intel HD GMA 3000?
» Prototype 125 watt monoblock tube amplifier KIT
» 2500 King Setra List
» Kitt 3000 wanted
» Kitt 3000 wanted
» Yter Speaker Cable 5m banana
» Shunyata Research Cobra Etron Series 1.8m Power Cord
» Shunyata Research Anaconda 1.8m Power Cord
» proton amplifier model AM-455
» 3 pillars speaker stand (new)
» Bowers & Wilkins B&W CM1 Bookshelf Speakers in Maple, made in UK (Used)
» Bowers & Wilkins B&W ASW 675, 500W Active Subwoofer, made in UK (Used)
» Bowers & Wilkins B&W 603 S3 Floorstanding Speakers, made in UK (Used)
» AudioQuest Forest 3D 1.4 HDMI Cable (Used/Demo)
