Technics SL-2000 Direct Drive Turntable with Stanton 500 AL II MM Cartridge (Sold)
2 posters
Description
The SL-2000 is designed for those who want direct drive performance at a moderate cost.
This beauty is equipped with Technic's famous brushless DC motor, which operates free from power line fluctuations and trouble causing heat and hum.
The absence of moving parts in the motor means better reliability and longer service life.
Completely accurate platter speed is guaranteed by a one chip IC servo control, a simple and compact unit equivalent to 78 electronic components.
The result of all this precision is wow and flutter of only 0.045% WRMS and rumble of -70dB DINB.
A precisely manufactured tonearm ensures minimum tracking error and optimum mass distribution for high compliance cartridges.
Clear and clean sound reproduction is assisted by the insulation fibre board and a newly developed insulator which effectively shields the motor and tonearm assembly from outside vibrations.
The heavy zinc diecast tonearm base also works to prevent vibration and subsonic resonances.
Other features of the SL-2000 include a fine-scale direct reading anti-skating device, an illuminated stroboscope, independent pitch controls variable by up to 10%, viscous damped cueing, aluminium diecast universal headshell, and detachable dust cover.
Type: direct drive
Motor: low speed electronically controlled brushless DC motor
Platter: 30cm aluminium diecast
Speeds: 33.33 and 45rpm
Speed change: electronic change
Pitch control 10% adjustment range
Wow and flutter: 0.045% WRMS
Rumble: -70dB
Tonearm: Universal S-shaped tubular arm
Effective length: 220mm
Overhang: 14mm
Note : Mounted Magnetic Stanton 500 AL II MM Phone Cartridge
Price : RM Sold
Last edited by HiFiLab on Mon Nov 12, 2012 7:37 am; edited 1 time in total (Reason for editing : sold)
- Number of posts : 2967
Re: Technics SL-2000 Direct Drive Turntable with Stanton 500 AL II MM Cartridge (Sold)
Hi, stock still available?
destomato- Club Member
- Number of posts : 30
Registration date : 2012-08-15
» Technics Direct Drive Turntable SL3200 (SOLD)
» Technics SP-25 Quartz Direct Drive Turntable (Used) SOLD
» Technics Direct Drive Turntable SL-1200MK3D (Used) SOLD
» Technics SL-120 Direct Drive Turntable - no tonearm (Used) SOLD
» TECHNICS SL-Q303 Direct Drive Turntable ~SOLD~
