Acoustik-Lab Stella Opus speakers (Used)Sold
Acoustik-Lab STELLA OPUS Speakers,Condition 8.5/10, Refine Finishing, Very Rare in Malaysia market.Made in Swiss
System 2 ways, 3 speaker bus reflex system, a Tallboy type, and a magnetic-shield type
Use unit For low-pass: 16cm corn type x2
For high regions: 3.5cm reverse dome shape
Frequency response 33Hz - -25kHz three dB
Crossover 3.2kHz
Sound pressure level 89dB/m/W
Input level 200W (music)
Impedance 8ohms
Finishing Lacquer finishing: Poplar, piano black, Yellow Bird eye Front Panel (One Piece up)
Mat finishing: A pier, an oak
Dimensions Width 250mm x height 1010mm x depth of 320mm
Weight 38kg
The speaker system developed under the design concept of "demonstrating the engine performance of a proprietary unit to the maximum extent."
Two 16cm corn type Woofers are carried in low-pass.
In this unit, in consideration of relation of sound with a tweeter, coating processing was carried out to the paper corn of natural material, and also the diaphragm in which the damping characteristic of a high region has the five-cornered diaphragm form which is gentle and has little coarse resonance is adopted.
Moreover, double voice coil structure is adopted and it is made to operate as a completeness parallel drive also electrically and mechanically.
The reverse dome shape tweeter of 3.5cm is carried in the high region.
What blended bio-cellulose (natural fiber) 50% and carbon fiber 50% is adopted as the diaphragm of this unit. This was newly developed in four years, and when [ of bio-cellulose ] a detailed fiber overly wraps in a carbon fiber firmly, it is stopping an umbrella umbrella sound peculiar to a carbon fiber depended for rubbing.
Moreover, the neodymium magnet is adopted as a magnet.
Since both a high region and low-pass units have adopted the double magnet system, it does not have the influence on the cathode-ray tube by leakage flux etc.
The extremely low tweeter of fo is used with a margin, and the distorted feeling which is easy to generate near crossover frequency is stopped.
Moreover, the intermodulation distortion to an inside region is removed by driving the diaphragm amplitude of a double Woofer by a new bus reflex theory controlled to the minimum.
Price : Rm. Sold Nego.
Contact : Roy 012-3890333
flowtech333- Dealer\Reseller\Trader\Service Provider
- Number of posts : 23
» Acustik Lab Bolero Grande Floorstands and Stella Centre Speakers (sold)
» Wharfedele Opus 2 Tri-Surround Speakers
» WTS - Wharfedale OPUS 2 Version 2 speakers
» Opus 3: Special 20th Anniversary Celebration Disc. Collection of Jazz and Classical recordings from Opus 3 catalog. 1992 Opus 3. HDCD Audiophile recordings. Made in Sweden by DCM.
