SINE Power Conditioner / Isolation Transformer / Automatic Voltage Regulator (NEW)
SAF - 30A Power Conditioner RM2700
Features and Specification
> 30Amps Hi-End EMI Filter is employed
> 12 AWG Solid Core Copper is used in internal wiring
> Extra thick Gold plated outlet and IEC male with Cryogenic Treatment
> Damping Material filled inside the chassis to reduce resonance and unwanted vibration
> Equiped with Hi-End Grade Compensation Capacitor
> A Special compensation circuit to enhance the flow the electricity
> 15mm Aluminium Alloy Chassis
> Input Voltage: 100 - 250VAC / 50Hz - 60 Hz
> Maximum Loading: 6600 Watts (220V), 3300 Watts (110V)
> Dimension: (L) 290mm (H) 90mm (W) 125mm
> Net Weight: 5.7 KG
> Gross Weight: 6 KG
> Colour: Black, Silver
SAT - 3KV (V2) Isolation Transformer
Features and Specifications
> 3000VA (15 Amps) Isolation Transformer
> 4 Pairs Top Quality Duplex Outlet
> Extra thick Gold plated outlet and IEC male with CryogenicTreatment
> Equipped with Hi-End Grade Compensation Capacitor
> 30 Amps circuit breaker with Cryogenic treatment
> 8 mm Aluminium Alloy Chassis
> Dimension: (D) 325mm (H) 270 mm (W) 145mm
> Net Weight: 24 KG
> Gross Weight: 29 KG
> Colour: Silver
SRT - 3KV Automatic Voltage Regulator
> Automatically adjusts the voltage to the levels that are suitable to your hifi equipment.
> Capacity: 3000VA ( 3000W )
> Input Voltage : 185V - 245V 50/60Hz
> Output Voltage : Select from 205V to 235V
> Response Time : 15-20 mini second
> Output Distorion : No distortion, the same as input waveform
> Protection : Circuit Breaker ( 15A )
> Dimension: (D) 285mm (H) 330 mm (W) 145mm
> Net Weight: 22 KG
> Gross Weight: 26 KG
> Colour: Black
Email [You must be registered and logged in to see this link.] for detail & Special Price. Thank you for viewing.
> Net Weight: 5.7 KG
> Gross Weight: 6 KG
> Net Weight: 24 KG
> Gross Weight: 29 KG
> Colour: Silver
> Net Weight: 22 KG
> Gross Weight: 26 KG
> Colour: Black
Skylines Audio- Dealer\Reseller\Trader\Service Provider
- Number of posts : 185
Registration date : 2012-10-23
Re: SINE Power Conditioner / Isolation Transformer / Automatic Voltage Regulator (NEW)
Some of SINE products have arrived at KL. We are having special promotion from now until 31 January 2013. Discount is available for SINE products including pre-order items. Do not miss this chance to own SINE product at lower price.
Email [You must be registered and logged in to see this link.] for more detail. Thank you for viewing.
» SINE Power Conditioner / Isolation Transformer / Automatic Voltage Regulator (NEW)
» SINE SRT-3KVĀ Automatic Voltage Regulator (Used)
» SINE SRT-3KV Automatic Voltage Regulator (Sold)
» Power Bright Full Automatic AC Voltage Regulator
» Right Power SDC-3000 Automatic Voltage Regulator (sold)
