Anthem Integrated 225 pre-owned for sales
Very good condition 9.5/10
Seldom used
One year plus only
Price: rm3900
016-332 1616
esmsb8@gmail.com
If interested photo will be provided through email
Anthem Integrated 225 Specifications:
PHONO PREAMPLIFIER
Input Impedance : 47 kΩ
Input Capacitance : 100 pF
Maximum Input : 18 mV at 20 Hz, 140 mV at 1 kHz, 160mV at 20 kHz
Gain (At 1 KHz) : 35 dB
Crosstalk (At 1 KHz) : 80 dB
RIAA Response : +/- 0.5 dB (100 Hz to 20 kHz); -1 dB (20 Hz)
THD+N (at 1 kHz, 5 mV input) : 0.05%
S/N Ratio (ref. 5 mV at 1 kHz, IEC-A filter) : 83 dB
PREAMPLIFIER
Input Impedance : 30 kΩ
'Pre-Out' Output Impedance : 560 Ω
'Rec-Out' Output Impedance : 100 Ω
Rated Input : 1.0 Vrms
Maximum Input : 7.6 Vrms
Minimum Load : 5 kΩ
Rated Output (100 k1 load) : 1.0 Vrms
Maximum Output (100 k1 load) : 7.6 Vrms
Headphone Output : 500 mW into 32 Ω at 0.03% THD+N
Channel Separation (at 1 kHz) : 75 dB
Crosstalk Between Inputs (At 1 KHz) : 72 dB
XLR Pin Configuration : Pin 1: Ground; Pin 2: Positive; Pin 3: Negative
Frequency Response And Bandwidth : 20 Hz to 20 kHz (+0, -0.1 dB); 1 Hz to 170 kHz (+0, -3 dB)
THD+N (at rated input and output, 80 kHz BW) : 0.003%
IMD (CCIF at 15 kHz and 16 kHz) : 0.0005%
S/N Ratio (A-weighted, ref 2.0 Vrms) : 105 dB
POWER AMPLIFIER
Frequency Response : 20 Hz to 20 kHz (+0, -0.15 dB)
Bandwidth : 1 Hz to 200 kHz (+0, -3 dB)
THD+N : 0.01% at 1 kHz, 0.03% at 20 kHz (100 W into 8 1)
Power Bandwidth : < 10 Hz to 100 kHz (+0, -3 dB, 200 W into 8 1)
Slew Rate : 25 V/µs
Headroom : 1.4 dB (8 1), 2.8 dB (4 1)
Damping Factor : 80 at 1 kHz (ref. 8 1)
S/N Ratio (A-weighted, ref 225 W) : 105 dB
Crosstalk : > 57 dB (100 Hz to 10 kHz)
Voltage Gain : 29 dB
General Specifications
Output Channels : 2
Features : Phono Input
DIMENSIONS
Width : 5-7/8 inches (14.9 cm) including feet
Height : Width 17-1/4 inches (43.8 cm)
Depth : 18 inches (45.7 cm)
Weight (Unpacked) : 42.6 lb
Seldom used
One year plus only
Price: rm3900
016-332 1616
esmsb8@gmail.com
PHONO PREAMPLIFIER
PREAMPLIFIER
Minimum Load : 5 kΩ
POWER AMPLIFIER
Slew Rate : 25 V/µs
Output Channels : 2
DIMENSIONS
esmsb8@gmail.com- New Member
- Number of posts : 2
Registration date : 2013-01-05
» Cardas speaker cable pre-owned for sales
» Anthem “Integrated 225” integrated amplifier, 225W/CH (SOLD)
» Anthem AVM 40 Pre/Pro (used)
» Anthem Integrated 225 Amplifier SOLD
» Anthem 225 integrated & Von Schweikert VR 1 Ref monitor (used)
