FS : Art Vinyl Play & Display Flip Frame
2 posters
The Art Vinyl Play & Display flip frames are finally IN.
Art Vinyl is the original way to display your favorite vinyl record art and to get more pleasure from the album. Changing your vinyl display is very easy as the flip frame has a unique quick release system allowing you to instantly change your record display. The flip frame is available in both black and white. The frame was designed especially to compensate for any differences in thickness of album or 12" record. This is done by the unique "sponge finger" system on the back of the flip frame, which will ensure that any record can fit comfortably against the front display panel.
The retail price for the single pack is S$60 and triple pack at S$170. For a limited period for the CNY celebration (till 24th Feb 2013), we are offering :
1 x single pack : S$60
2 x single pack :S$120 S$115
3 x single pack :S$180 S$166
1 x triple pack :S$170 S$166
2 x triple pack :S$340 S$326
3 x triple pack :S$510 S$469
Please visit [You must be registered and logged in to see this link.] or [You must be registered and logged in to see this link.] to view what's it all about and why it's having a cult following in Europe and parts of the world. Hear Records is the sole distributor of Art Vinyl in Singapore.
Please feel free to email [You must be registered and logged in to see this link.] or call Nick 96460648 for any queries and order.
Happy New Year. Cheers
2 x single pack :
3 x single pack :
1 x triple pack :
2 x triple pack :
3 x triple pack :
hearrecords- Dealer\Reseller\Trader\Service Provider
- Number of posts : 85
Registration date : 2013-02-02
Notice : HEAR Records Opening
Good day to all,
With respect to last post, i mentioned that HEAR Records (Singapore distributor for MUSIC HALL turntables & electronics, and ART VINYL; and retailer for New & Used Lps) will be opening in March at Burlington Sq, and i've been receiving emails and calls from interested/concerned folks in the last days asking when is official opening. So i think better clarify before people go down and waste their trip. Now the shop is under renovation, and should hopefully be ready in another week time.
You might like to go to [You must be registered and logged in to see this link.] to take a look at the shop (before renovation) and the HEAR Records's LOGO. I'll probably post the reno transformation process as we go along.
Will keep everyone posted once opening date is confirmed. I'm so sorry that i have to reject all customers wishing to come for viewing in the last 2 weeks due to the crazy schedule on preparation, I'll make it up.
Have a nice weekend. cheers
How to get better sound from vinyl records?
Good day to all,
What can you do to get better sound from vinyl records? One way to achieve higher fidelity is to purchase more sophisticated equipment, such as upgrading a turntable, tonearm, cartridge, phono preamps or all of the above. Or, you can tweak your current system using some conventional. HEAR Records brings you 3 products from MUSIC HALL to accessorize and enhance any analog setup.
1. MUSIC HALL Decoupling Cork Mat
A seemingly simple lightweight mat, the Music Hall Mat is made entire from cork and is designed to be a direct replacement for virtually any turntable mat. The secret to the Mat's great sound are the cork pads which suspend the record, a dozen small pads around the outside of the Mat and a single larger one for the spindle. These cork pads have excellent damping characteristics and do a great job protecting the record from the platter's vibration and allowing the vinyl to "speak" on its own. An additional advantage of the Music Hall Mat is its ability to "grip" the platter and the record simultaneously, eliminating the micro-slippage that plagues standard felt mats. This gives the Mat greater focus and improves pacing, especially on complex passages or those with substantial low-frequency content.
REVIEW : [You must be registered and logged in to see this link.]
2. MILTY Zerostat Anti-static Gun (Stereophile Recommended Component)
This amazing little device known as the Milty Zerostat Antistatic Gun is an antistatic generator which has numerous applications, but our main use is to remove the satic charge on the surface of a record. Just squeeze the "trigger" of the Zerostat and a steady stream of ions is released. The magic comes from two powerful piezoelectric crystals and its patented compression trigger. The Zerostat will simply remove a static charge from the surface of an LP instantly. Perfect for use when the rotation of a Record Cleaning Machine and its suction tube build up a static field on the surface of your records. The Zerostat eliminates this static charge with the pull of the trigger. Highly recommended... in fact... this is an essential analog accessory!
3. HUNT EDA Mark 6 Brush (Stereophile Recommended Component)
"Properly used (held with the bristles at a low angle against the approaching grooves and slowly slid off the record), these are the most effective dry record-cleaners avail-able. (JGH disagrees, feeling that they leave the dust on the record.) No substitute for an occasional wet wash." - Class D, 10/96, Page 141, review Volume 10 #8.
Please go to [You must be registered and logged in to see this link.] to connect with us or come down to
HEAR RECORDS
#01-39 Burlington Square
Singapore
Please contact Nick +65 96460648 or email [You must be registered and logged in to see this link.] for further queries. HEAR RECORDS is the local distributor for MUSIC HALL turntables & electronics. Thanks 4 reading.
HEAR RECORDS
Singapore
Promo : MUSIC HALL Turntables
Good day,
Music Hall LLC was founded in April 1985. It is a company dedicated to manufacturing, importing and distributing well priced, top quality, high-end audio components. Its emphasis is almost exclusively 2-channel (stereo); a rarity in this day of iPods and multi-channel products. It has grown over the years to become one of the pre-eminent distribution and manufacturing companies in the industry. Music Hall manufactures its own range of turntables in the Czech Republic. These are produced in a factory that has been making turntables for over 50 years. All Music Hall turntables come fitted with arms, cartridges and dust covers. They consistently make the "Recommended Components" list in Stereophile Magazine.
HEAR Records is the Singapore distributor of Music Hall turntables & electronics. We are currently doing a promotion whereby we're giving 10% discount on all Music Hall turntable models (limited units on each models). Please visit [You must be registered and logged in to see this link.] or contact Nick +65 96460648 for further information. or better still come to HEAR Records (@Burlington Square Singapore) to audition.
Music Hall MMF-2.2
"The MMF-2.2 gets my strong recommendation as a top choice for an entry-level turntable for budding audiophile looking to put together a first analog system or ready to replace an aging table" - Tood Whitesel (Audio Video Revelation)
Music Hall MMF-5.1
"One night i cleaned the LP and put it on the MMF-5.1 i was flush with anticipation - i haven't heard this LP in a dozen years - and i wasn't disappointed. I remembered every instrumental line, every vocal inflection, every lyric. When the second side was done, i played the entire album again. if sitting through a whole album is a sign of involvement with music, sitting through a whole album twice is a sign of something greater - involvement with memories. Analog did this for me. The Music Hall MMF-5.1 did this for me." - Marc Mickelson (Soundstage)
"So good it's laughable. The MMF-5.1 is a "plug & play" design you can have up and running in 10 minutes. It's a gateway drug into the intoxicating world of analog playback. Get hooked you'll never go back" - MNichael fremer (Stereophile)
Stereophile Recommended Component / Stereophile Michael Fremer recommended / Absolute Sound's editor's choice
Music Hall MMF-7.1
Music Hall MMF-9.1
Music Hall MMF-2.2
Music Hall MMF-5.1
Music Hall MMF-7.1
Music Hall MMF-9.1
NEW : Music Hall DAC - Digital Done Right
Good day to all,
Music Hall has significantly upgraded the Award-Winning DAC25.2 to the DAC25.3! The upgrade was to the USB input which now accepts 24bit/96kHz signals. The Music Hall DAC25.3 is natively compatible with Windows 7/Vista/XP/2000 and Mac OS X.
HEAR Records is the Singapore distributor for Music Hall turntables & electronics. Please visit/contact us at Burlington Square or [You must be registered and logged in to see this link.] or Nick (+65 96460648). HEAR is selling the DAC15.2 at S$445 and DAC25.3 at S$885, and do delivery to Malaysia.
musichallaudio.com/product_reviews/tonedac25_2.pdf
apartmenttherapy.com/product-realview-music-hall-da-93470
Today an increasing number of music lovers are buying storing and listening to music through their computer, media server, or personal music player (iPod). Many are also digitally distributing their music using a sonos, squeezebox, or one of a host of digital music distribution systems available on the market. This is a great way to explore and appreciate music but generally it's done at the expense of sound quality. Until now, music lovers have been forced to rely on the inferior digital to analog converters (DACs) and sounds cards contained in those devices. As a result, their musical enjoyment has dramatically suffered. Music Hall has designed the DAC25.3 to directly address this problem and to significantly improve the sound quality of the music played on these systems.
By uniting a state of the art digital to analog converter (DAC) with a tube output we produce the clarity and precision of a 24bit DAC with the warm rich open sound people love of tubes. The Music Hall DAC25.3 has 4 digital inputs which can accept any coax (s/pdif), optical, XLR (AES/EBU), or USB digital input from an iPod transport, computer, media server, sonos, squeezebox, CD/DVD in stereo transport, or music hall's own CD35.2 Compact Disc Player, and it will output two channel stereo analog.
The Music Hall DAC25.3 features the latest Texas Instruments (formerly Burr-Brown) PCM 1796 24bit/192kHz, advanced segment, stereo audio digital to analog converter. This processor features 123dB dynamic range an 8 x oversampling digital filter and just 0.0005% thd. The dac25.3 upsamples to either 96kHz or 192kHz which is user selectable on the front panel. To achieve the best sound, Music Hall uses an advanced asynchronous reclocking and anti jitter control system upstream of the PCM 1796 DAC. For this system the philips 74HC574 is used in conjunction with the TI SRC4192 asynchronous sample rate converter whose master clock is a high precision active crystal oscillator. The Music Hall DAC25.3 also features a large r-core high current oversize power transformer. A headphone output is provided for convenient personal listening.
Features:
• USB Input Accepts 24bit/96kHz Signal
• Electro-Harmonix 6922 Tube Single-Ended (RCA) Output
• Solid-State Differential Balanced Output
• TI PCM 1796 24bit/192kHz DAC
• TI SRC 4192 Asynchronous Sample Rate Converter
• High Precision Active Crystal Oscillator Master Clock
• User Selectable 96kHz or 192kHz Upsampling
• Asynchronous Reclocking and Anti Jitter Control System
• 8 x Oversampling Digital Filter
• 4 Digital Inputs: Coax (s/pdif), Optical, XLR (AES/EBU), or USB
• 2 Gold Plated Outputs; Single Ended (RCA), Balanced (XLR)
• Headphone Output with Adjustable Analog Volume Control
• Large High Current Oversize R-Core Power Transformer
• Thick Brushed Aluminum Fascia and Solid Chassis
• 110v/220v Voltage Selectable Transformer
• Detachable Power Cord
Features:
wnmeshop- Dealer\Reseller\Trader\Service Provider
- Number of posts : 36
Registration date : 2013-06-17
NEW : Music Hall Turntables & Electronics
Good day to all
musichallaudio.com/products.php?l=3
HEAR Records (@ Burlington Square) is the Singapore distributor for Music Hall. Turntables start from S$390 and electronics start from S$265. Please call Nick +65 96460648 for further queries or just come down for a demo. facebook.com/hearrecords
cheers
cheers
PROMO : Music Hall Turntables & Electronics
Good day to all,
Just got in is a new lot of 1000+ used LPs and 200+ Japanese Pressed 7" for sale. There're also ~800+ New & re-issue LPs and 2000+ used LPs in store. Prices starts from S$10 up.
We are doing a Children day special whereby all Music Hall turntables & electronics and Art Vinyl frames go for 10% off for today & tomorrow to kids, which means everybody since we are all kids with music & hifi, we need TOYS.
artvinyl.com
HEAR Records (located at Burlington Square Singapore) is the local distributor of Music Hall electronics & turntables. Please go to facebook.com/hearrecords or contact +65 96460648 for more queries.
greatnewplaces.com/sg/c1976-HEARRecords
cheers
artvinyl.com
cheers
NEW : How to get better sound from Vinyl Records
Good day
How to get better sound from vinyl records? Here is a link for your reference
goldminemag.com/article/high-fidelity/how-to-get-better-sound-from-vinyl-records
After much wait, the Music Cork Mat (S$60) is finally back in stock after several rounds of sold out. Here are some reviews from end-users : needledoctor.com/Music-Hall-Mat
HEAR Records (@ Burlington Square Singapore) is the Singapore distributor for Music Hall products. Please go to facebook.com/hearrecords or 96460648 for queries. HEAR also stocks the Milty Zerostat 3 (S$145) and Hunt EDA Brush (S$39).
cheers
cheers
NEW : Music Hall electronics & turntables
Good day to all,
Looking for a setup, amplifier, or turntable to start a new year? Preferably good and reasonably priced? Then U might want to check out Music Hall.
MUSIC HALL was founded in USA 1985. They are a company dedicated to manufacturing well priced, top quality, high-end audio components. Their emphasis is almost exclusively 2-channel (stereo), a rarity in this day of iPods and multi-channel products. They have grown over the years to become one of the pre-eminent distribution and manufacturing companies in the industry. Music Hall manufactures its own range of turntables in the Czech Republic. These are produced in a factory that has been making turntables for over 50 years. All Music Hall turntables come fitted with arms, cartridges and dust covers. They consistently make the “Recommended Components” list in Stereophile Magazine.
HEAR Records (@ Burlington Square) is the Singapore distributor of MUSIC HALL electronics & turntables. Please check out facebook.com/hearrecords or contact Nick +6596460648 for details on the products. prices starts from S$265.
Thanks for reading. cheers
FS : Used Vinyls at S$10 each
Good day to all,
Hear Records is a music lifestyle store located at Burlington Square Singapore, retailing new and used vinyl records. We’re the local distributor of Music Hall (US) turntables and electronics, as well as Art Vinyl (UK).
We are having a new used LPs shipment 1000++ this week, and need to clear some space. So is clearing a few hundreds of the older used titles for Sin$10 each. Please check out facebook.com/hearrecords
drop by if free
thanks for reading
drop by if free
thanks for reading
» QED-U-Play Plus-Bluetooth-(NEW)
» ART Vinyl to display your LP covers
» Weiduka ac 8.8 latest 4 display and Tp 1000 4 display
» QED - U-Play Plus - Bluetooth - (New)
» QED-U-Play-Bluetooth-(NEW)
