Stabilizer Transformers
Hi there,
I am letting go my UK made Cetronics constant voltage transformer and Watford power stabilizer. They are very heavy about 38kg and 45kg each. Both are dual wound transformers. I use both connected in series to have an ultra stable voltage. The voltage is adjustable in the Watford while Cetronics provide either 240V or 220V fixed.
The Cetronics comes with 4 pairs of capacitors which will function even if one or two fail. It was designed as such to provide uninterrupted power supply. I have replaced the capacitors (user replaceable) with the ones recommended by Mr. Oh. The originals capacitors can be purchased from Cetronics for about UK$250 for a set of eight. The images attached herein and the actual items are the same except mine looks dusty and old. I will post actual photos on request.
These transformers run hot and hum slightly due to the industrial type transformer design and recommended to be placed outside the music room or at least 15 feet away from your sitting position.
Cetronics Constant Voltage Transformers key features. 2kVA
A CVT incorporates an isolation transformer automatic voltage regulator all in one and offers the following benefits:
• Transient Suppression • Voltage Stabilisation
• Mains Distortion Removal • Automatic Overload Protection
Condition: 6 due to dirty surface
Price: RM1000 nego
Watford key features 2kVA:-
Ultra fast response
Low internal impedance capable of sustaining high surge currents.
Stability maintained over the full range of input voltage variations, frequency variations and from zero to full load at any lagging power factor.
Efficiency better than 94% with up to 96% on higher models.
Full transverse mode interference suppression fitted as standard. This will suppress any spikes, transients or noise between line and neutral and line to line to a harmless ripple
Common mode interference suppression fitted when required. This option will eliminate any potential difference, spikes or noise between earth and neutral or earth to line.
Condition: 6 due to dirty surface. Performance is unaffected.
Price: RM1000 nego
I can be contacted at 019 three eight three 3 two 5 nine (Whatsapp or SMS only) or PM me. For more details about the transformers, please go to http://www.watfordcontrol.com/be-stabilisers.php and http://www.cetronicpower.com/
Thank you.
Price: RM1000 nego
Ultra fast response
Price: RM1000 nego
Thank you.
Re: Stabilizer Transformers
BUMP...Price negotiable. The benefit of these transformers cum stabilizer cum conditioner is better controlled music.
» Step-down Transformers
» Custom Make Transformers
» WE Input Transformers D162065
» G.E.C. 48H Audio Input Transformers
» Lp clamp stabilizer ( new )
