Onkyo TX-SR705 AV receiver (Used)SOLD
Onkyo TX-XR 705 AV amplifier
Power output : 160 w into 6 Ohm per channel (& channel)
Price : Rm SOLD
Condition : 9/10 (1.5 Years Usage Only)
C/w Box, Remote & Accs.
Contact : Roy :- 012-3890333
Product Specifications
Amplifier Section
Power Output -
Front L/R 100 W + 100 W (8 ohms, 20 Hz–20 kHz,
0.08%, 2 channels driven, FTC)
Center 100 W (8 ohms, 20 Hz–20 kHz, 0.08%,
Surround L/R 100 W + 100 W (8 ohms, 20 Hz–20 kHz,
Surround Back L/R 100 W + 100 W (8 ohms, 20 Hz–20 kHz,
Dynamic Power 240 W (3 ohms, 1 ch)
210 W (4 ohms, 1 ch)
120 W (8 ohms, 1 ch)
THD (Total Harmonic Distortion) 0.08% (Rated power)
Damping Factor 60 (Front, 1 kHz, 8 ohms)
Input Sensitivity and Impedance 200 mV/47 k-ohms (Line)
2.5 mV/47 k-ohms (Phone MM)
Output Level and Impedance 200 mV/470 ohms
Phono Overload 70 mV (MM, 1 kHz, 0.5%)
Frequency Response 5 Hz–100 kHz/+1 dB, -3 dB (Direct mode)
Tone Control ±10 dB, 50 Hz (Bass)
±10 dB, 20 kHz (Treble)
Signal-to-Noise Ratio 100 dB (Line, IHF-A)
Speaker Impedance 4 ohms–16 ohms or 6 ohms–16 ohms
Video Section
Input Sensitivity/Output Level and Impedance -
Video 1 Vp-p/75 ohms (Component and S-Video Y)
0.7 Vp-p/75 ohms (Component PB/CB, PR/CR)
0.28 Vp-p/75 ohms (S-Video C)
1 Vp-p/75 ohms (Composite)
Component Video Frequency Response 5 Hz–50 MHz (-3 dB)
Tuner Section
Tuning Frequency Range -
FM 87.5 MHz–107.9 MHz
AM 530 kHz–1,710 kHz
FM/AM Preset Memory 40 stations
General
Power Supply AC 230 V, 60 Hz
Power Consumption 6.2 A
Dimensions (W x H x D) 17 1/8" x 6 7/8" x 14 13/16"
(435 x 174 x 377 mm)
Weight 28.4 lbs. (12.9 kg)
flowtech333- Dealer\Reseller\Trader\Service Provider
- Number of posts : 23
» Onkyo FR-435 CD/MD/FM Receiver (Used) SOLD
» Onkyo TX-SR705 AVR (used)
» Onkyo TX-SR705 AVR (used) - CLOSED
» Onkyo-TX-SR 706-AV Receiver-(Sold)
» Onkyo TX-DS 939 A/V receiver (Used)SOLD
