Jolida Fusion System (Pre & Power) SOLD
Jolida Fusion system Preamp & Monoblocks (Demo 8.5/10) RMSOLD. Pls call or sms 016-5501015
Preamp Technical Specifications:
Max Output voltage: 20 dB
Voltage Gain: 30 V
Frequency Response: 5Hz to 110KHz, 10 V
Distortion THD: Less than .02%; 1 KHz, 10 V
SNR: Less than 100 dB
Input Impedance: 100Kohms
Output Impedance: 600 ohms
Weight: 28 pounds
Size: 17 inches W X 13 inches D X 4.5 inches H
Tube Complement: 2 pcs. 12AX7; 2 pcs. 12AT7 Premium Tungsol Tubes
Construction Details and Features:
Multiple outputs: Fixed out, XLR out, RCA out.
Multiple Inputs: Front mounted selector switch and mini jack, with a pair of XLR and RCA inputs. Also includes a bypass input.
Custom Wound Audio Transformers with a core of German grain oriented silicon steel. 15th generation proprietary design
State of the Art Components: ALPS audio potentiometer, gold plated RCA input and output jacks. Includes custom made polypropylene capacitors, ESA Clarity Caps and Hexfred diodes.
All Metal Remote control
Monoblocks Technical Specifications:
Rated Output Power: 200 W per channel at 8 ohms, 25Hz to 40KHz
Frequency Response: (at 1 watt into 8 ohms) 14Hz to 50KHz + 1dB
Distortion THD: Less than 1% at 150 W output, 21Hz to 28KHz
Circuit Type: Ultra Linear, Class AB
Input Sensitivity: 2.35mV at 1KHz and 8 ohms for 200 watt output
Output Impedance: 4 ohms and 8 ohms
Tube Complement: 2 pcs. 211 power output; 2 pcs. El34 power drivers, 2 pcs. 12AT7 power drivers.
Thanks!
Last edited by danieltan on Tue Feb 04, 2014 4:37 pm; edited 1 time in total (Reason for editing : Update status)
danieltan- Dealer\Reseller\Trader\Service Provider
- Number of posts : 70
Registration date : 2009-05-25
Source(s): Jolida
Amplification: KR Audio
Speakers: Von Schweikert Audio
Source(s): Jolida
Re: Jolida Fusion System (Pre & Power) SOLD
Source(s): Jolida
Source(s): Jolida
Source(s): Jolida
» Jolida Fusion 3000 Monoblocks (New)
» Jolida Fusion Preamp & Monoblocks (New)
» Tannoy Fusion 4 Floorstanding Speaker ( SOLD )
» Jolida JD 3000A tube mono block power and Pre amp
