FS: Soundfield SF 2 tube top loading cd player
Selling a excellent sounding Soundfield SF 2 solid state / tube top loading cd player. Super solid built with rice cooker type top cover and magnetic clamp. Can be use as a cd transport or as a straight cd player with 3 sets of output. 1 is solid state rca, another is tube rca and the third output is XLR balance output. Randomly use only as I have couple of cd player. Selling now due to moving to computer music and need funds. Looking at just SGD $1500. Set is in Singapore. Please email microgolf@singnet.com.sg if keen. thanks.
Features:
-Top-loading structure, 100mm Aluminum alloy mechanism base, SONY optical system & Philips servo.
-High accurate clock system.
-Burr-Brown BB1738 DAC chip.
-S/N reaches 117dB.
-THD reduce to 0.0004% (-107.96 dB).
-Sampling range 10-200KHz, 24Bit decoding accuracy, 8 times over-sampling filter, digital compensation, digital.
-Output level 2.2 Vrms, output currenct 2.48mA.
-6 pieces OPA for analogue amplification, 2 R-form transformer for digit & analogue respectively.
-Outputs: one group coaxial digital & one group OPA, one group 6922 tube, one group XLR.
-Power supply filter to make background more silence, Low-resistance & high accuracy voltage stable power supply for analogue & control curcuit without mutual disturbance to more accurate position and more live stage.
-Quality components like Auricap capacitors, Solen capacitors, Philips capacitors, single crystal interconnects, CMC terminals etc.
Technical Data:
-Output Level: RCA 2V (+/- 0.5dB)
XLR 4V (+/- 0.5dB)
-Frequency Range: 10Hz - 20KHz (+/- 0.3dB)
-Dynamic Range: 117 dB
-THD: <= 0.005%
-Outputs: XLR x1, RCA x2 (Solid x1, Tube x1)
-Digital Outputs: Coaxial x1
-Size: (L xW xH) 463 x480 x195mm
-Net Weight: 23.5 Kgs
Features:
-S/N reaches 117dB.
Technical Data:
XLR 4V (+/- 0.5dB)
-THD: <= 0.005%
James46- Frequent Contributor
- Number of posts : 241
Registration date : 2012-12-30
» Mhzs top loading tube cd player
» Pro Av CD1 Hi End Top Loading Tube HDCD CD Player
» Ayon CD-07 Top-Loading Tube CD Player
