Audio Pro Piano Black Vector v.2 Center Speaker
[font=Times New Roman][img]https://i.servimg.com/u/f83/18/31/55/09/111.jpg[/img][size=12][color=#000000]
[img]https://i.servimg.com/u/f83/18/31/55/09/211.jpg[/img][/color][/font]
[b][color=white]Audio Pro Piano Black Vector v.2[/color][/b]
[b][color=white]Technical data:[/color][/b]
[b][color=white]Enclosure:...................Passive radiator[/color][/b]
[b][color=white]Drive units: (Shielded)[/color][/b]
[b][color=white]Tweeter:............1” Super Tweeter[/color][/b]
[b][color=white]Mid range:..........................3,5”[/color][/b]
[b][color=white]Woofer:..............................6,5”[/color][/b]
[b][color=white]Passive radiator................. 6,5”[/color][/b]
[b][color=white]Crossover:.................800Hz / 2.200Hz[/color][/b]
[b][color=white]Frequencyrange:..............40-35.000Hz[/color][/b]
[b][color=white]Sensitivity: (1W / 1M)....................89dB[/color][/b]
[b][color=white]Impedance:..................................4ohm[/color][/b]
[b][color=white]Amp. requirement:...............25 - 125 W[/color][/b]
[b][color=white]Dimensions:(WxHxD mm)....560x185x270[/color][/b]
[font=Calibri][color=white]The Black Vector V2 is the enhanced, more tech-loaded version of the Audio Pro
center channel loudspeaker. It sports the same aesthetics and pretty much the
same functionality but has taken things to a higher level, with the addition of
a fourth driver, voiced for a better reproduction of the midrange sound. Due to
the new 3” midrange driver, this section of the audio spectrum has been
dramatically enriched, allowing the Black Vector V2 to proudly enter the
high-end field. [/color][/font]
[font=Calibri][color=white]While sporting the same sober elegance of the entire Image series, the Black Vector
V2 also comes with extended versatility and is even more handy: because of an
enforced midrange reproduction, the output sound covers a wider area, allowing
a better, larger sweet spot.[/color][/font]
[font=Calibri][color=white]Built with Audio Pro proprietary drivers, the Black Vector V2 sports a thorough magnetic
shielding allowing you to place it under your TV or above it without fear of
image distortions. The wooden cabinet is carefully voice-matched for perfect
compatibility with the other speakers in the Level series and the internal
strutting and damping materials ensure a vibration-free performance even in
prolonged listening sessions or at high levels. [/color][/font]
[font=Calibri][color=white]As for the rest, the driver complement is a d'Appolito array running on dual 6.5”-coned
woofers with exceptional bass reproduction capabilities extending down to a
very serious 40Hz bottom end; while only one is actively driver, the other
serves as an air-coupled passive radiator. Between these drivers a 1” soft dome
tweeter has been placed, loaded in its own faceplate for better insulation
against vibrations coming from the woofers; its response reaches a staggering
25,000Hz frequency, allowing for a neat reproduction of music from SACD or
DVD-Audio tracks as well. [/color][/font]
[color=#000000][font=Calibri][color=white]The Audio Pro Black Vector V2 can offer you a max power of 125W with 4 Ohms impedance and
works with 89dB sensitivity.[/color][/font][/color]
[font=Calibri][color=white]Condition: 8/10[/color][/font]
[font=Calibri][color=#ffffff]Weight: 12.7 kg[/color][/font]
[font=Calibri][color=#ffffff]Price: RM1100 Nego[/color][/font]
[font=Calibri][color=#ffffff]Contact: hcy 0139280118[/color][/font]
Last edited by hcy on Mon Jul 15, 2013 3:26 pm; edited 1 time in total (Reason for editing : Own Use.)
hcy- Club Member
- Number of posts : 26
Registration date : 2013-05-21
Re: Audio Pro Piano Black Vector v.2 Center Speaker
The Black Vector V2 is the enhanced, more tech-loaded version of the Audio Pro Image 22 center channel loudspeaker. It sports the same aesthetics and pretty much the same functionality but has taken things to a higher level, with the addition of a fourth driver, voiced for a better reproduction of the midrange sound. Due to the new 3” midrange driver, this section of the audio spectrum has been dramatically enriched, allowing the Black Vector V2 to proudly enter the high-end field.
While sporting the same sober elegance of the entire Image series, the Black Vector V2 also comes with extended versatility and is even more handy: because of an enforced midrange reproduction, the output sound covers a wider area, allowing a better, larger sweet spot.
Built with Audio Pro proprietary drivers, the Black Vector V2 sports a thorough magnetic shielding allowing you to place it under your TV or above it without fear of image distortions. The wooden cabinet is carefully voice-matched for perfect compatibility with the other speakers in the Level series and the internal strutting and damping materials ensure a vibration-free performance even in prolonged listening sessions or at high levels.
As for the rest, the driver complement is a d'Appolito array running on dual 6.5”-coned woofers with exceptional bass reproduction capabilities extending down to a very serious 40Hz bottom end; while only one is actively driver, the other serves as an air-coupled passive radiator. Between these drivers a 1” soft dome tweeter has been placed, loaded in its own faceplate for better insulation against vibrations coming from the woofers; its response reaches a staggering 25,000Hz frequency, allowing for a neat reproduction of music from SACD or DVD-Audio tracks as well.
hcy- Club Member
» Mirage OMD-28 Floor Stand Tower Speaker in Piano Black - Used
» Audio Pro Black Vector V.2 Center Speaker (Used) SOLD
» SVS Prime Elevation Height/Surround Speaker, Piano Gloss Black
» AudioPro - Black Vector V.2 - Center Speaker (Used)
» XTZ 99.25 Piano Black Finish Speaker (Used)SOLD
