FS: Jas Audio Bravo 2.1 high end tube int amplifier
Selling excellent condition Jas Audio Bravo 2.1 high end tube integrated amplifier. Very good sounding. Fast, rhythmic and transparent. Local set 230 volts and come with original metal cage, owners manual, remote and box. MSRP US$1600. Selling sgd $950 ono. Set is in Singapore. Email microgolf@singnet.com.sg if keen. Thanks
http://soundapproach.com/jasaudio-bravo-6n5p-integrated-amplifier-p-1465.html
Bravo 2.1 features application of low internal resistance 6N5P (6SA7) vacuum tubes that facilitates sound reproduction in a relatively huge sound stage. It is also outstanding in its performance of sound controllability at a power output of 30W per channel. Designed with a unique driving circuit, enhancing current damping of 500V or above, Bravo 2.1 excels its counterparts by delivering dynamic sound while still maintaining a relatively low distortion. Multi-tier signal driving circuit helps deliver crystal clear and transparent sound with details to listeners. Bravo 2.1 is supplied with a remote control.
The use of low internal resistance 6N5P (6SA7) vacuum tubes in Bravo 2.1 facilitates sound reproduction that casts a relatively huge sound stage and outstanding performance in controllability of sound at a power output of 30W per channel. Designed with a unique circuit, enhancing current damping of 500V or above, Bravo 2.1 excels its counterparts by delivering dynamic sound while still maintaining a relatively low distortion. Multi-tier signal driving circuit helps deliver crystal clear and transparent sound with details to listeners.
Specifications:
Power Handling: 30W X 2
Frequency Response: 0Hz(-0.5dB )---20KHz ( -3dB )
Display Device: None
Input Sensitivity: 83dB
Input Impedance: 47K omega
Tube Type: 6N5P X 4 6N1 X 2 6N2 X 1
Signal-to-Noise Ratio: 1.1% ( 28W )
Inputs: N/A
Outputs: N/A
Dimensions: 430(W)x160(H)x310(D)
Weight: 40lbs
Accessory: Remote Control
Specifications:
Inputs: N/A
Outputs: N/A
Weight: 40lbs
James46- Frequent Contributor
- Number of posts : 241
Registration date : 2012-12-30
» Kalypso High End hifi audio Tube Amplifier Handmade in UK
» Bravo tube amp (used)
» Magnat MA600 High End Hybrid Tube Integrated Amplifier (Germany)
» Lite T-62 high end tube stereo power amplifier (used)
