B&W 700 Series - 703 floorstanders, HTM 7 center and 705 bookshelf speakers (used)
2 posters
B&W 703 |
B&W HTM 7 |
B&W 705 |
set is consisted of 1 pair of B&W 703 floorstanders, 1 unit of HTM 7
center channel and 1 pair of B&W 705 bookshelf speakers. Owner is
letting go the speakers due to upgrade.
Made in England. Condition: 8.5/10. With original boxes.
Items sold.
703 4-driver, 3-way, ported-box speaker
Drivers: 1" alloy dome tweeter, 6.5" woven-Kevlar cone FST midrange, 2 6.5" paper/Kevlar cone woofers
Frequency range: –6dB @ 30Hz & 50kHz
Frequency response: 38Hz–25kHz, +/-3dB, on reference axis
Sensitivity: 90dB/2.83V/m
Nominal impedance: 8ohms, minimum 3.0ohms
Crossover frequencies: 350Hz, 4kHz
Power handling: 50–200W @ 8ohms, unclipped
Dimensions: 39.7" x 9.1" x 14.1" (HxWxD)
Weight: 60 lbs
HTM7 2-driver, 2-way, ported-box, magneticaly shielded center-channel speaker
Drivers: 1" alloy dome tweeter, 6.5" woven-Kevlar cone woofer/midrange
Frequency range: –6dB @ 46Hz & 50kHz
Frequency response: 50Hz–25kHz, +/-3dB, on reference axis
Sensitivity: 91dB/2.83V/m
Nominal impedance: 8ohms, minimum 4.6ohms
Crossover frequency: 4kHz
Power handling: 50–120W @ 8ohms, unclipped
Dimensions: 17.7" x 12.1" x 11.4" (WxHxD)
Weight: 28 lbs
705 2-driver, 2-way, ported-box speaker
Frequency range: –6dB @ 43Hz & 50kHz
Frequency response: 46Hz–25kHz, +/-3dB, on reference axis
Sensitivity: 89dB/2.83V/m
Crossover frequency: 3.7kHz
Dimensions: 16.5" x 8.75" x 11.4" (HxWxD)
Weight: 21 lbs
http://www.hometheater.com/content/bw-703-htm7-705-asw750-surround-speaker-system-specifications
Reviews:
Please contact Max 017-6778820 or Benjamin 016-3229428 for appointments and negotiations.
We are open on Sundays!
Re: B&W 700 Series - 703 floorstanders, HTM 7 center and 705 bookshelf speakers (used)
where's your location, can audition ? RM 10,000 for whole set ?
LeCouple- Regular
- Number of posts : 79
Registration date : 2011-01-03
Located in Seremban. Can be auditioned. Sorry to say that RM10k is not possible. Will consider if the offer is better than that. Thanks.
» Bose 201 Series V Bookshelf Speakers
» Bowers & Wilkins DM603 S3 Floorstanders, DM600 S3 Bookshelf, LCR60 S3 center (used) SOLD
» Any regrets upgrading from bookshelf speakers to floorstanders?
» SOLD-Monitor Audio BR2 Bookshelf & Center M Series
» KEF iQ10 Q Series Uni-Q Bookshelf Speakers
