Arcam Alpha 9 British Stereo Amplifier with Remote (Sold)
A Sonic Pearl – Virtually Mint Arcam Alpha 9 Integrated Amplifier
Renowned Sonic Purity & Dynamic Headroom
Complete Remote Control (Compatible Type),
Designed and Built in England,.
Arcam definitely sound different than most components, and have an ultra pleasing warmth and total absence of harshness or electronic ‘grundge’ sound. Their signature sound has been called “NAD on Steroids” because while they have the warmth and pleasing mid tones of many NAD amplifiers, they have stronger dynamics and better, more robust build quality.
Here is Information from Arcam:
Arcam's Alpha 9 integrated amplifier rivals the best separate pre and power amplifier packages and set new standards in sound quality, aesthetics and flexibility.
The amplifier delivers a continuous power output of over 70 watts per channel into 8 ohms, with both channels driven.
The sound is clean, powerful and beautifully transparent with both digital and analogue sources,
All the key electronic parts are of audiophile standard and are mounted on a single, through-hole-plated computer grade circuit board.
All input and output sockets are gold plated.
The high current VMOSFET power amplifiers are directly coupled to remove sound compromising capacitors from the signal path.
Ample reserves of power are assured by the use of a massive 400VA toroidal transformer.
The Alpha 9's flexibility makes it the ideal control centre for a sophisticated hi-fi or A/V system.
Six line inputs, including two tape loops, are standard; a seventh (phono) input is an optional extra - please discuss with your dealer for further details.
Two independently switched pairs of loudspeaker sockets and a headphones socket are included, so you can run two sets of speakers in separate rooms if required.
Finally, the bypassable limited range tone and balance controls allow you to fine tune the amplifier settings to suit your listening environment and system requirements. It is easy to add Audio-Video capability systems using the Alpha 9. It has properly buffered pre-amp out and power-amp in sockets, as well as two tape loops.
For optimum results we suggest you couple the Alpha 9 to an Arcam Alpha 9P integrated amplifier, using the 9P to drive the speaker's bass/mid-range units, whilst the integrated amplifier's original power amplifiers are retained to drive the treble units. A bi-amplified Alpha 9/9P combination sounds superb. Twin paralleled pairs of gold-plated input sockets allow the daisy chaining of extra power amplifiers and the easy parallelling of both channels when required. A headphones jack socket is also included.
The Alpha 9 integrated amplifier provides a natural sonic upgrade path for many home cinema amplifiers / receivers, including all Arcam models. It may also be matched to a wide variety of preamplifiers. The Alpha 9 can be used to increase your system’s available power or may be used to achieve outstanding results in bi-amplified or tri-amplified systems.
If you buy both of these amps (the Arcam Alpha 9 power amp and the Arcam Alpha 9 integrated amp) and want to Bi-Amp them, it is really a simple process. You do not need anything other than another pair of Interconnects to connect the two amplifiers, and a second set of speaker cables, and of course Bi-Amp capable speakers. Arcam advises to use the 9P to drive the woofers, and have the 9 Integrated drive the tweeters and midranges..
ARCAM ALPHA 9 INTEGRATED AMPLIFIER SPECIFICATIONS:
* Design: Solid-state power amplifier
* Output power:
… 70W into 8 ohms, both channels driven (20 dB W)
… 140W into 4 ohms, both channels driven (19.3 dB W)
* Harmonic distortion: 0.02% typical (1kHz at 100W, 8 ohms)
* Peak current rating: ± 18A
* Crosstalk: -80dB at 1kHz
* Frequency response: 10 Hz – 20,000 Hz, -0.5dB
* PREAMP Line & Tape Inputs:
… Frequency Response: 20 Hz – 20,000 Hz (+/- 0.5 dB)
… Noise (CCIR) Ref. Rated Output: 98 dB
… Input Sensitivity: 160 mV
… Tone Controls at 50Hz, 10,000 Hz: +/- 8 dB
… Input impedance: 5,000 ohms
* PREAMP Outputs:
… Nominal Output Level: 650 mV
… Maximum Output Level: 8V
… Output Impedance: 100 Ohms
* Arcam Alpha 9 Integrated Amp Physical Dimensions:
… Width: 16.93” (430mm)
… Depth: 13.00” (330mm)
… Height: 3.74” (95mm)
* Weight net 29.5 pounds unpackaged
Price : RM Sold
Last edited by HiFiLab on Tue Jun 10, 2014 12:32 am; edited 1 time in total (Reason for editing : Sold)
- Number of posts : 2967
BUMP
BUMP
» Arcam Alpha 6 British Stereo Integrated Amplifier With Phono and Remote (Sold)
» Arcam Alpha 5 PLUS British Stereo Integrated Amplifier ( Sold )
» Arcam Alpha 7 British Made CD Player with Remote ( Used )
» Arcam Delta 290P British Stereo Power Amplifier (sold)
» Arcam Alpha 9 Stereo Power Amplifier ( Sold )
