Acoustic Energy Aego-T speaker system (Sold)
Aego T
Sumptuous style meets class-leading home cinema sound.
In a sea of compact home cinema loudspeaker systems Acoustic
Energy’s Theatre System leads the way in performance and design. From
the curved alloy cabinets, that promote low resonance and negate
internal standing waves, to the lustrous gloss black finish, the
T-system is the perfect balance of form and function for the home.
The five matched satellite speakers use AE’s deisgned bass drivers
and tweeters to produce a rich and well balanced sound that integrates
smoothly with the matching subwoofer. Twin 200mm drivers powered by a
200Watt amplifier in a sealed cabinet ensure that the T-System
subwoofer offers both thunderous low frequency effects and the
lightning fast bass response demanded by music reproduction.
With heavyweight build quality and high-end components used
throughout, the T-System sets a new standard in compact home cinema
loudspeaker packages, while remaining competitively priced. The
T-system is supplied with compact wall brackets for each satellite
speaker.
Aego-T Satellite
Type: Two-way, closed box compact speaker. Mid/Bass
Driver: 100mm damped fiber cone with 25mm thermally bonded voice coil.
Shielded high-Power long-throw magnet system.
HF Driver: 25mm Pre-coated textile dome with Ferro-fluid cooled neodymium magnet system and Rear heat sink.
Filter Network: 2nd and 3rd order at 3.5kHz. Cabinet: Injection molded and die-cast Aluminum hybrid.
Frequency Response: 100Hz to 20kHz ±3dB
Frequency Range: 75Hz to 30kHz @-6dB
Power Handling: 100W peak programme
Amplifier Compatibility: 25 -100 Watts into 8 Ohms
Nominal Impedance: 8 Ohms
Sensitivity: 86.0dB for 1 Watt at 1 meter
Dimensions (H x W x D): 202 x 124 x 146mm
Weight: 2.5kg (single, unpacked)
Finish: High Gloss Black
Aego-T Subwoofer
Type: Closed box, opposed driver active Subwoofer.
Drivers: 2 x 200mm fiber cone with 48mm Thermally bonded voice coil. Shielded high-power Long-throw magnet system.
Low Frequency Cut-off:-6dB @30Hz
Amplifier: 200 Watts into 4 Ohms
Low Pass Filter: 2nd Order at 250Hz
Input Sensitivity: 300mv for rated output
Dimensions (H x W x D): 390 x 360 x 420mm
Weight: 18.5kg (single, unpacked)
Finish: High gloss black
Bought this guy last year. It is still in Mint condition, 9/10 i would say. 3 out of the 5 satellite is still unused, I only used 2 satellite and the sub. I initially plan to use it for movies, but my time ended up for listening to music and to work Rather than letting the speakers lose they purpose, idling for nothing, I would rather let them go for someone who would appreciate them.
Sold to Mr Kevin. Thanks a lot.
speaker.
Aego-T Satellite
Aego-T Subwoofer
Last edited by runemaster on Tue Oct 27, 2009 11:22 am; edited 1 time in total (Reason for editing : Item Sold)
runemaster- Regular
- Number of posts : 99
Registration date : 2009-09-23
» WTS: Acoustic Energy Aego M-System (Pearl White) - SOLD
» Acoustic Energy AEGO T 5.1 speaker set (Used)
» Acoustic energy aego 2 (used) Sold
» Acoustic Energy Aego M (Black, Used) SOLD
» Acoustic Energy Aego-M 2.1 active speakers (Sold)
