WTS:SL-2000A Pre amp (stylish design)
This excellent pre-amp is available at [You must be registered and logged in to see this link.]
Call / Msg +65 83195040 if interested
now selling at SGD650
SL-2000A
SL-2000A Preamp with volume remote control
Tube compliment: 2 12AT7 line tubes / 1 5Z4P rectifier
AB-Allen Bradley NOS key resistors, gold PCB and tube sockets
Pure silver signal wires; Wooden radio remote control, two RCA inputs and two outputs.
Frequency Response: 10-30KHz +/- 1.5dB
Harmonic Distortion: <0.5%
Signal-to-Noise Ratio: >84dB
Dimensions: (LxWxH) 285x140x140mm
Weight: 4Kgs
SL-2000
Tube preamp with phono input. Separate power supply module for a improved noise floor.
A simple design but great performance
Class-A
Separate power supply unit
Phono input
Tubes: 6Z4 X 1, 12AX7 X 1, 12AT7 X 1
Size: 22.5 cm X 12 cm X 9.5 cm
Weight: 6.5 Kg (including the power supply)
Call +65 83195040 for discount
SL-2000A
Weight: 4Kgs
SL-2000
Class-A
Phono input
analogaudiolabs- Dealer\Reseller\Trader\Service Provider
- Number of posts : 263
» WTS: Dared SL-2000A Pre amp (stylish design )
» Dared SL-2000A Pre amp
» DARED MP-5-- A stylish tube hybrid amp
