Sansui AU-999 Stereo Intergrated Amplifier (Sold)
The Integrated Amplifier which hits the upgrade version of AU-777D in the highest-class model of PB series of an SANSUI.
Aiming at the play of a more faithful sound, the thorough listening comprehension test was accumulated and it was developed.
The main-amplifier part has adopted the perfect direct coupling system of plus-or-minus 2 power source of a two-step differential-amplification circuitry and an output Capacitor-Less. NFB became equal from a super-high region to super-low-pass one by this, and many properties are improved.
The PNP silicon transistor with few noises is used for the equalizer stage with the three-step E-E NF type, and it has acquired a low-noise, a low distortion, an extensive dynamic range, and high stability.
The hardwired-connection circuitry is used for the amplifying circuit as much as possible, the required fraction of the coupling capacitor used the Mylar capacitor as much as possible, and the phase distortion in a high region has banished the bad large electrolytic capacitor of a transmission characteristics.
The triple tone control original with an SANSUI is adopted as a tone control part, and Bass and not only Treble but a coordination of Midrange is possible.
The tone selector with which a defeet, and a going up point and a descending point are changed to two frequencies, respectively, low and the loud sound of 2dB which can perform an exact coordination, and the it1 step type of inside sound the step of 1dB are adopted.
A pre-main part is separated and an independent using is possible.
Two tape decks can use it simultaneously and carry the TapetoTape reprint switchpoint.
Moreover, a stereo balance check circuitry, a level adjuster, NF type row / high filter, a tuner selector, a mike input jack, the muting switch, the special-NetWare-program indicator, the headset jack, the DIN connector, etc. are carried.
Old School Sansui AU-999
Condition : 7/10 , Had been Fully Recapped and Serviced.
Price : RMSold
Contact : Simon Ting : 012-3612507
Last edited by HiFiLab on Mon Nov 25, 2013 9:46 am; edited 1 time in total (Reason for editing : sold)
- Number of posts : 2967
Price : RM2650
» Sansui Stereo Intergrated Amplifier AU-7900 (Sold)
» Vintage Sansui AU-666 Stereo Intergrated Amplifier (Sold)
» Sansui AU-9500 Stereo Intergrated Amplifier (sold)
» Sansui AU-6500 Stereo Intergrated Amplifier with MM MC Phono ( Sold)
» Vintage Sansui AU-5500 Stereo Intergrated Amplifier (Sold)
