Hafler XL-600 EXCELINEAR Stereo 305Watts Power Amplifier (Used)
Made In USA
This amplifier is insanely powerful, the dynamic swings are incredible. David Hafler was way ahead of his time with this one. Direct coupled with no capacitors in the signal path.
Unique EXCELINEAR circuit allows you to tailor the amp to YOUR speakers. These amps can almost drive a dead short.
Note: Suitable for ElectroStatic Speaker
It is in good condition and it performs excellently… It is conservatively rated at 305w/ch at 8ohm 450w/ch at 4ohm it also has a bridge switch in the back which will allow you to run it in mono.
SPECIFICATIONS POWER RATING:
CONTINUOUS POWER AT CLIPPING: *
Into 8 ohms, per channel: 360 watts
Into 4 ohms, per channel: 500 watts
Into 2 ohms, per channel: 750 watts
Into 1 ohms, per channel: 900 watts
Into 8 ohms, mono: 1000 watts
Into 4 ohms, mono: 1500 watts
Less than 0.08% THD at any power level up to 305 watts per channel into 8 ohms at any frequency from 20 - 20 kHz with both channels driven. CONTINUOUS POWER OUTPUT: 450 watts per channel into 4 ohms at less than 0.1% THD, 20 - 20 kHz. 900 watts in mono into 8 ohms at less than 0.1% THD, 20 - 20 kHz. CONTINUOUS POWER AT CLIPPING: * Into 8 ohms, per channel: 360 watts Into 4 ohms, per channel: 500 watts Into 2 ohms, per channel: 750 watts Into 1 ohms, per channel: 900 watts Into 8 ohms, per channel: 1000 watts Into 4 ohms, per channel: 1500 watts IM DISTORTION (SMPTE): Less than 0.04% from 1 watt to 305 watts into 8 ohms. FREQUENCY RESPONSE @ 1 WATT INTO 8 OHMS: +/- 0.1 dB, 10 Hz to 50 kHz +/- 3 dB, 0.1 Hz to 500 kHz POWER BANDWIDTH: Greater than 100 kHz PHASE SHIFT FROM 20 - 20 kHz: Less than 1/4 of one degree SLEW RATE: 10 kHz, 130 volts peak-to-peak square wave: 100 V/us SIGNAL TO NOISE RATIO, UNWEIGHTED: More than 100 dB @ 305 watts into 8 ohms INPUT: 47,000 ohms; 1.8 volts for 305 watts into 8 ohms DAMPING FACTOR INTO 8 OHMS: > 200 to 1 kHz; 150 @ 10 kHz
PHYSICAL Dimension : 7” high, 19” wide, and 13” deep, plus 1/2” for feet, plus 2” for handles.
Net weight 51 Ibs. = 23kg
This power amp is truly an iron fist in a velvet glove. It mixes sheer power with subtlety and finesse. It is insanely powerful and the dynamic swings are incredible. David Hafler was way ahead of his time with this one. Direct coupled with no capacitors in the signal path. Unique EXCELINEAR circuit allows you to tailor the amp to YOUR speakers.
As a follow up to the X L280 power amplifier Hafler released this new, more powerful model, the XL600. Hafler's "excilinear" concept of near-zero phase-shift circuitry, offering a linear transfer characteristic under both static and dynamic conditions, is further refined in this amplifier. It employs a double-differential J-Fet push-pull cascoded input and current-mirroring second stage, driving 16 lateral MosFet output devices to provide 360 Watts continuous power into 8 Ohms (900 Watts into I Ohm) for less than 0.05 per cent total harmonic distortion. Some 30dB less overall feedback is used compared with previous Hafler designs yet it remains completely stable. Entirely separate power supplies are used after the mains transformer (72,000uF of smoothing in all), with a further supply for the low-level stages. The heatsink is cooled by a proportional speed fan.
As I say, this amp has served me superbly. It has a slightly obtrusive fan noise when in full operation and for this reason I have always preferred to site it under the stairs on in a different room away from where the sound of the music is enjoyed.
This is obviously a personal choice and probably not essential to everyone!
Price : RM 3250
- Number of posts : 2967
BUMP
HiFiLab wrote: BUMP
» Hafler XL 600 excelinear power amp (Used)SOLD
» Hafler 9300 Transnova Stereo Power Amplifier (Used) SOLD
» Hafler XL-280 Power Amplifier
» Hafler pre n power amplifier
» Hafler 9180 Power Amplifier - Sold
