Van Den Hul Contact Treatment and Protection Fluid - The Solution (New)
Van Den Hul Contact Treatment and Protection Fluid - The Solution (New)  Empty Van Den Hul Contact Treatment and Protection Fluid - The Solution (New)
Post by aiyen on Tue Dec 24, 2013 6:38 pm
For perfect contact treatment and protection
Why care for your audio contacts?...
The electrical audio contacts made by the interconnects in your installation represent an often overlooked vulnerable part in the audio signal path and much harm can be done to the audio signal transferred at these points.
Through frequent plugging and unplugging your contacts will start to wear. Also, the connector contacts will unavoidably start to pick up pollution and even might corrode somewhat.
With polluted connectors there will be no perfect metal to metal contact; On microscale there will be some semiconductive layer in between, building a barrier for the weakest audio signals where terms as resolution, ambience and definition reside.
Also through this messy non-linear contact barrier the audio signal current will start to intermodulate with the noisy ground leakage currents flowing through the shield contacts and shields of your interconnects (to minimize those, please refer to our POLARITY CHECKER).
This again will mask low level audio information.
Burn in effects and directionality found with some audio cables also partly can be pointed towards polluted contacts.
The SOLUTION:
The metal-metal contact between e.g. the binding post and the cable connector must be kept clean and durable without any interference from the outside world.
Van Den Hul therefore supply The SOLUTION, an ageing free contact fluid specially intended for audio applications.
The SOLUTION performs three simple but useful functions:
Contact cleaning.
Stabilising contacts against chemical attack from atmospheric pollutants.
Contact lubrication, reducing subtraction and insertion wear on the connector’s precious metals.
The SOLUTION is standardly applied to all our interconnects before packing. With Van Den Hul’s RCA type connectors the fluid slips in the gap of the centre pin and spreads around after connecting in the female chassis plug. So the first treatment is already there.
From experience Van Den Hul know that the result is time stable and helps improve the sound.
Sales Unit:
The SOLUTION is supplied in small bottle with an application brush incorporated in its screw lid.
Content: 25 cc., an amount that will serve you for many years.
Some application and contact cleaning tips:
Before applying The SOLUTION on old, often used connectors, it is advisable to pre-clean their contact surfaces by rubbing them thoroughly with a piece of rough paper (never use sandpaper!) wetted with some pure alcohol (also useful to clean the heads of your cassette recorder); When looking at the piece of paper used for cleaning you can see the dirt that has come off!
No copious amounts are needed. Simply wiping the lightly wetted brush along the contact surfaces to be treated suffices.
The SOLUTION does not age and provides a long time protection to your audio contacts; When frequently plugging / swapping interconnects one however might consider to re-apply The SOLUTION every once in a while.
 Van Den Hul Contact Treatment and Protection Fluid - The Solution (New)  1453311_164789650397541_313186482_n
Price : RM259.00 (Shipping not included).
Please contact us at 012-614 3049 (Ms Wee) or 016-725 5372 (Wendy)  for further details or to arrange for viewing at our showroom situated at Taman Melaka Raya, Melaka.
Mode of payment :
- COD anywhere in Malacca town area / our showroom
- PBB for purchase made outside Malacca.
FB : [You must be registered and logged in to see this link.]
aiyen
Number of posts : 1178
Registration date : 2010-08-24
Van Den Hul Contact Treatment and Protection Fluid - The Solution (New)  Empty Re: Van Den Hul Contact Treatment and Protection Fluid - The Solution (New)
Post by aiyen on Tue Jan 07, 2014 1:21 pm
Bump ~
aiyen
Post by aiyen on Sat Jan 18, 2014 8:17 pm
Bump ~
aiyen
Post by aiyen on Sun Jan 26, 2014 11:42 pm
Bump ~
aiyen
Post by aiyen on Tue Feb 25, 2014 8:58 pm
Bump ~
aiyen
Post by aiyen on Wed Mar 19, 2014 12:14 am
Bump ~
aiyen
Post by aiyen on Fri Mar 28, 2014 10:57 pm
Bump ~
aiyen
Post by aiyen on Mon Apr 21, 2014 10:31 pm
Bump ~
aiyen
Post by aiyen on Sat May 10, 2014 12:27 pm
Bump ~
aiyen
Post by aiyen on Tue May 27, 2014 12:09 am
Bump ~
aiyen
Post by aiyen on Fri Jun 06, 2014 1:49 pm
Bump ~
aiyen
Post by aiyen on Mon Jun 16, 2014 4:18 pm
Bump ~
aiyen
Post by aiyen on Thu Jun 26, 2014 3:48 pm
Bump ~
aiyen
Post by aiyen on Wed Jul 09, 2014 10:52 pm
Bump ~
aiyen
Post by aiyen on Sat Jul 19, 2014 12:23 pm
Bump ~
aiyen
Post by aiyen on Fri Aug 01, 2014 1:10 am
Bump ~
aiyen
Post by aiyen on Fri Aug 29, 2014 11:13 pm
Bump ~
aiyen
Post by aiyen on Mon Nov 10, 2014 8:17 pm
Bump ~
aiyen
Post by aiyen on Sat Jan 31, 2015 9:31 pm
Bump ~
aiyen
Post by aiyen on Tue Mar 10, 2015 12:46 am
Bump ~
aiyen
Post by aiyen on Mon Apr 20, 2015 9:44 am
Bump ~
aiyen
Post by aiyen on Thu Apr 30, 2015 9:50 am
Bump ~
aiyen
Post by aiyen on Tue May 12, 2015 11:14 am
Bump ~
aiyen
Post by aiyen on Thu May 28, 2015 9:31 am
Bump ~
aiyen
Post by aiyen on Thu Jul 16, 2015 1:42 pm
Bump ~
aiyen
Post by aiyen on Fri Aug 21, 2015 10:06 am
Bump ~
aiyen
Post by aiyen on Fri Sep 04, 2015 10:21 am
Bump ~
aiyen
Post by aiyen on Mon Oct 12, 2015 10:21 am
Bump ~
aiyen
Post by aiyen on Mon Oct 26, 2015 1:48 pm
Bump ~
aiyen
Post by aiyen on Tue Nov 03, 2015 9:34 am
Bump ~
aiyen
Post by aiyen on Tue Nov 24, 2015 2:51 pm
Bump ~
aiyen
Post by aiyen on Thu Dec 10, 2015 9:36 am
Bump ~
aiyen
Post by aiyen on Tue Dec 29, 2015 9:44 am
Bump ~
aiyen
Post by aiyen on Thu Jan 07, 2016 12:37 pm
Bump ~
aiyen
Post by aiyen on Wed Jan 20, 2016 9:36 am
Bump ~
aiyen
Post by aiyen on Tue Feb 23, 2016 2:59 pm
Bump ~
aiyen
Post by aiyen on Mon Mar 14, 2016 9:53 am
Bump ~
aiyen
Post by aiyen on Mon Mar 28, 2016 1:47 pm
Bump ~
aiyen
Post by aiyen on Mon Apr 11, 2016 9:55 am
Bump ~
aiyen
Post by aiyen on Tue May 31, 2016 10:13 am
Bump ~
aiyen
Post by aiyen on Wed Jun 08, 2016 2:27 pm
Bump ~
aiyen
Post by aiyen on Fri Jan 06, 2017 10:30 am
aiyen
Post by aiyen on Fri Aug 11, 2017 10:44 am
aiyen
Post by aiyen on Wed Nov 29, 2017 10:42 am
aiyen
Post by aiyen on Thu Mar 15, 2018 10:22 am
aiyen
Post by aiyen on Tue Jul 24, 2018 10:10 am
aiyen
Post by aiyen on Fri Feb 08, 2019 10:13 am
aiyen
