Nikko TRM500 Solid State Stereo Intergrated Amplifier (Used)
FRONT PANEL : Anodized silver. Upper level: Speakers: system A or B. Bass and treble controls. Balance. Selector : aux, tuner, phono1, phono2, dubbing. Volume. Lower level: Power switch. Power indicator. Headphone jack. Low and high filters. Mode:stereo/mono. Tape2 in and out. Tape selector: dubbing 1-2/play1/source/play2/dubbing 2-1. Function switch: 2 channel/4channel. Loudness.
REAR PANEL. Upper level : phono2,phono1,tuner,aux inputs. Pre-out and main in. Pre-Main connect/separate switch. Circuit breaker (secondary). Circuit breaker (primary) ( Protection of amplifier and secondary circuits from major damage due to overload and shorts). AC outlet (2 switched,1 unswitched, 200 w max total). Lower level: Ground terminal. Tape2 and tape1 in and out. Tape 2 and tape 1 DIN type connectors. System-B speaker terminals. System-A speaker terminals.
MADE IN JAPAN
(1970’s)
SPECIFICATIONS
RMS Power rating :
Both channel driven at 8 Ohms 22 + 22 w – at 4 Ohms 24+24 w
Frequency response: ± 2dB Aux input 20 Hz - 30 kHz
Distortion : rated output 0.8%
Intermodulation distortion : rated output 0.8%
Input sensitivity/impedance (rated output at 100 Hz):
Main in 1000 mV/100KΩ
Phono 2 mV/47kΩ
Power consumption : maximum 140 w
Transistor: 29
Diode : 9
Height 130mm Width 380mm Depth 320mm.
Weight: 8Kg
Very Powerful !!
like NAD 3020, it can Drive my Infinity Renaissance 90 4 ways floorstanding speaker
Price : RM sold
- Number of posts : 2967
HiFiLab wrote:
BUMP
BUMP
HiFiLab wrote:
BUMP
» Nikko Solid State Stereo Amplifier
» Luxman solid state stereo intergrated amplifier 700x
» Luxman Solid State Stereo Integrated Amplifier L-2
» Kenwood KA-4002a Solid State Stereo Amplifier (1970-73)
» Luxman CL 350 Solid State Stereo Control amplifier-sold
