Teddy Pardo Pre PR1
Teddy Pardo Pre PR1
TeddyPre PR1 - Pre Amplifier
The TeddyPre is a high-end two box pre amplifier, one box hosts the transformer while the other hosts the sensitive electronic circuits.
Like the Teddy Pardo DACs and Power Amplifiers, the TeddyPre is designed around the concept that the audio circuits should be minimalistic with the shortest possible signal path, while the complexity is moved to the power supply.
The TeddyPre has four auxiliary inputs and one home theater bypass input which can be used in conjunction with a home theater system and allows sharing the main speakers and power amplifier between the home theater system and a the audiophile stereo system. The home theater inputs can be replaced by a second output if needed.
Although the TeddyPre is a solid state pre amplifier, its design is based on concept taken from valve amplifiers and its sound characteristics resemble those of high end valve amplifiers, but without the inconvenience of heat and wear.
The TeddyPre is equipped with a remote control that controls the volume level and mute.
The TeddyPre is built using the best available components: selected low noise JFET transistors, low noise Tantalum and PPS capacitors, and WBT NextGen sockets. All components are mounted on a six layer immersion gold FR4 PCB with a real star ground topology
Condition : 8.0/10 , first hand with box.
Price :SOLD
Price :SOLD
sp1983- Frequent Contributor
- Number of posts : 458
Registration date : 2011-07-31
Re: Teddy Pardo Pre PR1
bump..
still available ... sms or call if interested.
Item sold to a gentleman...
» Teddy Pardo Dual Teddy Cap
» Teddy Pardo dualTeddyCap (sold)
» Teddy Pardo TeddySuperCap (Sold)
» Teddy Pardo DAC (SOLD)
» Teddy Pardo XPS (sold)
