Klipsch KG 3.2 Floorstanding Speaker with Horn Tweeter (Used)
Made In USA
The two-way KG Series KG 3.2 floorstanding loudspeaker was first introduced in 1992 and manufactured by Klipsch until 1994,
While no longer in production KG 3.2 model loudspeakers are still owned and listened to by Klipsch fans around the world as part of two-channel audio and home theater surround sound systems.
Frequency Response: | 36Hz-20kHz(+-)3dB |
SENSITIVITY: | 94dB @ 1watt/1meter |
POWER HANDLING: | 65 watts maximum continuous (325 watts peak) |
NOMINAL IMPEDANCE: | 8 ohms |
TWEETER: | K-84-K 1" (2.54cm) Phenolic dome compression driver |
HIGH FREQUENCY HORN: | 90(o)x60(o) Exponential Horn |
WOOFER: | K-1002-K 8" (20.32cm) ICG cone active / KD-101-K 10" (25.4cm) ICG cone passive |
ENCLOSURE MATERIAL: | Medium density fiberboard construction (MDF) |
ENCLOSURE TYPE: | Bass reflex via passive radiator |
DIMENSIONS: | 25.5" (64.8cm) x 12.4" (31.5cm) x 10.75" (27.3cm) |
WEIGHT: | 32 lbs. (14.5kg) |
FINISHES: | Finished Black |
Built From: | 1992 |
BUILT UNTIL: | 1994 |
Price : RM 1550
- Number of posts : 2967
» Klipsch KG 5.5 Tractrix Horn Tweeter Floorstanding Speaker (Sold)
» Klipsch Horn Tweeter, Horn Midrange and woofer
» Klipsch KG 4.5 with horn tweeter speakers( SOLD)
» Horn tweeter floorstand speaker
» klipsch kg3.5 horn speaker. ~ SOLD
