Chord Company Crimson Plus VEE Phono (2RCA) to Phono (2RCA) 1m Cable
Chord Company Crimson Plus VEE Phono (2RCA) to Phono (2RCA) 1m Cable Empty Chord Company Crimson Plus VEE Phono (2RCA) to Phono (2RCA) 1m Cable
Post by raymond88 Sat Jan 18, 2014 2:30 am
Item: Chord Company Crimson Plus VEE Phono (2RCA) to Phono (2RCA) 1m Cable
Condition: Item is only 2 months old and in MINT condition.
Used only for a while as already upgraded to better cables. comes in original box.
Price: RM270 or swap with your cables
Contact: 012-3816611  Raymond
Chord Company Crimson Plus VEE Phono (2RCA) to Phono (2RCA) 1m Cable Crimso10
Chord Company Crimson Plus VEE Phono (2RCA) to Phono (2RCA) 1m Cable Crimso12
Some info:
Chord Crimson Plus
2 RCA to 2 RCA Audio Lead
Now with New VEE Plugs
Real performance has always started with the Chord Crimson. The Crimson, benefited hugely from the development work carried out during the design of the Chord Signature interconnect.
In terms of configuration the cables are very similar.
Both share separately insulated signal and return conductors and a floating shield arrangement. This configuration is part of the reason that the original Crimson performed so well.
The new CrimsonPlus builds on the original Crimson's performance but takes detail levels and dynamics to a new level, stereo image is improved and CrimsonPlus has an extremely neutral tonal characteristic.
During the development of the latest Chord Company high end cable, we learned important lessons about the application of heavy gauge foil shielding. This knowledge has been taken and applied to the new CrimsonPlus.
The improvements are significant and whether the cable is used to link a hi-fi or home cinema, the results are remarkably consistent. The improved shielding also makes CrimsonPlus ideal for longer runs and the cable is particularly impressive when used with subwoofers
Use it with:
The improvements CrimsonPlus can bring can be further enhanced by using CrimsonPlus interconnects in combination with Carnival SilverScreen speaker cable and it is also worth introducing Chord SuperScreen mains cables. The three cables together produce an extremely cost-effective cabling system that will help a system to perform at its best and produce a genuinely musical and involving performance from almost any system. CrimsonPlus can also be used with Chord Carnival Classic speaker cable to good effect.
Terminations:
The CrimsonPlus is available fitted with gold-plated RCA plugs, Din plugs, gold-plated stereo minijack, Neutrik XLR balanced plugs with silver-plated contact areas and ¼ inch mono or stereo jack plugs.  CrimsonPlus can also be terminated with other connectors.  If you have a specific requirement, please contact us.
The CrimsonPlus is available in 0.5 and 1 metre lengths.  Custom lengths are available to order.  We do not recommend the use of Din cables in lengths shorter than 1 metre for reasons of sound quality.
Multi-strand oxygen free copper conductors
Pseudo-balanced twisted pair configuration, High frequency effective floating braid and foil shielding
Low density polyethylene conductor insulation, Vibration controlling outer jacket
Gold-plated Chord RCA plugs - also available in DIN and XLR configurations
Chord Company Crimson Plus VEE Phono (2RCA) to Phono (2RCA) 1m Cable Crimso13
  • Multi-strand oxygen free copper conductors
  • Pseudo-balanced twisted pair configuration, High frequency effective floating braid and foil shielding
  • Low density polyethylene conductor insulation, Vibration controlling outer jacket
  • Gold-plated Chord VEE RCA plugs - also available in DIN and XLR configurations
Thank you.
Number of posts : 10093
Chord Company Crimson Plus VEE Phono (2RCA) to Phono (2RCA) 1m Cable Empty Re: Chord Company Crimson Plus VEE Phono (2RCA) to Phono (2RCA) 1m Cable
Post by raymond88 Sun Jan 26, 2014 2:01 am
Post by raymond88 Sun Feb 02, 2014 2:46 am
Post by raymond88 Mon Feb 10, 2014 3:35 pm
Post by raymond88 Tue Feb 18, 2014 12:55 am
Post by raymond88 Wed Feb 26, 2014 1:47 am
Post by raymond88 Wed Mar 05, 2014 9:20 pm
